I assume the current userbase for MakeMKV on ARM64 is pretty small but I hope the following bug can still be fixed since recent changelogs also show ARM fixes.
For some reason (other people also confirmed it) UHD Blu-ray’s always error out in the beginning and want you to submit the dump for keys. Under Windows X86 the same Disc works just fine.
I also tried manually supplying a keydb.cfg but it still couldn’t decrypt.
[Bug] MakeMKV on ARM (linux)
Shield TV 2017 -> LG DSN10YG Soundbar with SPK8 Rears -> LG B1 OLED
Re: [Bug] MakeMKV on ARM (linux)
I edited three registry files: one to enable the batch script to be played via VLC's Autoplay of DVDs and Blu-rays, one to disable the commandeer function, and one to generate backup Autoplay listings specifically for DVDs and Blu-rays. As this is my first batch script in a while, I would appreciate any suggestions for enhancement.mtotheb wrote: ↑Thu Mar 28, 2024 6:28 pmI assume the current userbase for MakeMKV on ARM64 is pretty small but I hope the following bug can still be fixed since recent changelogs also show ARM fixes.
For some reason (other people also confirmed it) UHD Blu-ray’s always error out in the beginning and want you tophrazle submit the dump for keys. Under Windows X86 the same Disc works just fine.
What does this have to do with Arm64 linux?ineafowlahead wrote: ↑Mon May 06, 2024 3:55 amI edited three registry files: one to enable the batch script to be played via VLC's Autoplay of DVDs and Blu-rays, one to disable the commandeer function, and one to generate backup Autoplay listings specifically for DVDs and Blu-rays. As this is my first batch script in a while, I would appreciate any suggestions for enhancement.
I think I replied to a spam/copy-pasta thread at viewtopic.php?f=1&t=34275
I double-checked, but make sure you name it KEYDB.cfg (case-sensitive on Linux) or it won't be found.
That is so weird it seems to be a spam/copy of my account??segfaulted wrote: ↑Fri Jun 14, 2024 4:39 pmI think I replied to a spam/copy-pasta thread at viewtopic.php?f=1&t=34275
Was your success in the other thread without or with manually supplied KEYDB.cfg. Also super cool that you also did this with a Rockchip SBC. At first I was like no way this could work but then I asked myself why not and that’s how I ended up with this situation.I double-checked, but make sure you name it KEYDB.cfg (case-sensitive on Linux) or it won't be found.
It was done without the keydb.cfg file, only using MakeMKV's regular HK update to fetch the keys.mtotheb wrote: ↑Fri Jun 14, 2024 9:41 pmWas your success in the other thread without or with manually supplied KEYDB.cfg. Also super cool that you also did this with a Rockchip SBC. At first I was like no way this could work but then I asked myself why not and that’s how I ended up with this situation.
