HK files not downloading
philb1701
Post by philb1701 »
With the exception of the actual name of the media itself, I have been getting this error since June 13th, when John Wick Chapter 4 came out. It has continued with EVERY 4K media I attempt to rip. Blu-ray versions of the same title (specifically John Wick Chapter 4) work perfectly fine.
Automatic SDF downloading is disabled or failed.
Using LibreDrive mode (v06.3 id=64754CF46FCA)
Downloading latest HK to /Users/bark2995/Library/MakeMKV ...
Saved AACS dump file as /Users/bark2995/Library/MakeMKV/MKB20_v77_TIME_BANDITS_43C6.tgz
I am at a loss to understand what is happening and what to do about it.
I have confirmed internet access it turned on in the app.
I have verified that permissions are on via the macOS software (Ventura 13.4)
Read/write permissions have been turned on all the way up the chain right to the end user volume.
I used to rely on this program because it was reliable and it worked with a minimum of fuss and bother.
Unfortunately, I can no longer say that either is applicable now.
Any and all assistance would be greatly appreciated.
I'm open to trying almost anything.
Re: HK files not downloading
try clearing your dns cache or changing your dns
philb1701
Post by philb1701 »
Deleted my Ethernet connection and restored it.
Will try again later to connect.
Still seems funny that only the 4K media won't work.
Post by d00zah »
philb1701 wrote: Fri Jun 23, 2023 10:41 pm Still seems funny that only the 4K media won't work.
Only 4K media requires 'per release' hash key updates (AACS 2.x) to decode.
philb1701
Post by philb1701 »
I seem too have a recurrence of the problem.
I did have it resolved by setting up a VPN which did fix the problem earlier but doesn't seem to make a difference now.
So far it hasn't prevented me from converting the files I want with the exception of one that others are having problems with as well.
I will monitor the situation and update as need be.
