Troublesome Discs
MileHi2600
Troublesome Discs
Post by MileHi2600 » Wed May 01, 2024 5:46 pm
Hi all, I'm looking for some help ripping two discs.
First one is Rogue One Blu-Ray. I've cleaned the disc and I'm at a loss. I've ripped 150+ discs without issues. Disc also plays fine in a player. I recently purchased four new UHDs and ripped them fine. Logs attached.
The second disc is UHD Downton Abby A New Era. I've attached an image with the end of the logs. Apologies I don't have the entire log.
Any assistance with these two errors would be very helpful.
Thank you!
Re: Troublesome Discs
Post by dcoke22 » Thu May 02, 2024 4:34 am
Your attachments didn't attach and probably won't work on this forum. Just copy & past the logs into a post here and/or put at image at imgur with a link here.
Rojma
Post by Rojma » Thu May 02, 2024 5:58 pm
When cleaning the discs, make sure to use 91% isopropyl alcohol and a microfiber cloth. Always clean by wiping from edge to edge and not in a circular motion. I have found that doing this process has resolved about 90% of discs that I had trouble ripping. Using other cleaning methods usually made the problem worse.
I also recently found that cleaning the laser in the drive I use to rip, again with 91% isopropyl alcohol and a cotton swap, also solved the problem of ripping several discs that wouldn't rip. Trying multiple drives also sometimes helps (I have two LGs and one Samsung).
Every once in a blue moon I do find a disc that I can't rip no matter what I do. Sometimes I'll use ddrescue to try and get a successful image (again across different drives), but I would say that only works about 50% of the time. If I still can't get a successful rip, I usually contact the manufacturer/studio, tell them I have a bad disc, and they will send me a new disc. In each instance the replacement disc has always ripped, so sometimes there are discs out there that are bad and no matter what you do you won't be able to rip.
MileHi2600
Post by MileHi2600 » Thu May 02, 2024 7:09 pm
Excerpt from the logs:
The source file '/BDMV/STREAM/00818.m2ts' is corrupt or invalid at offset 2990942208, attempting to work around
The source file '/BDMV/STREAM/00818.m2ts' is corrupt or invalid at offset 2990942208-2990948352, attempting to work around
The source file '/BDMV/STREAM/00818.m2ts' is corrupt or invalid at offset 2990948352, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00818.m2ts' (title #-) , future messages will be printed only to log file
AV synchronization issues were found in file 'Z:/Scratch/Rogue One- A Star Wars Story_t05.mkv' (title #6)
AV sync issue in stream 3 at 0:09:12.960 with duration of 32ms : broken timecode, apparent audio skew is -64ms
AV sync issue in stream 3 at 0:09:13.024 with duration of 32ms : broken timecode, apparent audio skew is -384ms
AV sync issue in stream 3 at 0:09:13.088 with duration of 32ms : broken timecode, apparent audio skew is -352ms
AV sync issue in stream 0 at 0:09:13.115 : video frame timecode differs by -20.862ms
AV sync issue in stream 0 at 0:09:13.240 : video frame timecode differs by -62.565ms
AV sync issue in stream 0 at 0:09:13.407 : video frame timecode differs by -145.987ms
AV sync issue in stream 0 at 0:09:13.323 : video frame timecode differs by -104.27ms
AV sync issue in stream 0 at 0:09:13.532 : video frame timecode differs by -187.69ms
AV sync issue in stream 0 at 0:09:13.490 : video frame timecode differs by -187.693ms
AV sync issue in stream 0 at 0:09:13.657 : video frame timecode differs by -229.404ms
AV sync issue in stream 0 at 0:09:13.740 : video frame timecode differs by -271.109ms
AV sync issue in stream 0 at 0:09:13.824 : video frame timecode differs by -312.815ms
AV sync issue in stream 0 at 0:09:13.573 : video frame timecode differs by -229.398ms
AV sync issue in stream 0 at 0:09:13.698 : video frame timecode differs by -271.112ms
AV sync issue in stream 0 at 0:09:13.782 : video frame timecode differs by -312.818ms
AV sync issue in stream 0 at 0:09:13.865 : video frame timecode differs by -354.523ms
AV sync issue in stream 0 at 0:09:13.094 : video frame timecode differs by -41.708ms
Failed to save title 5 to file Z:/Scratch/Rogue One- A Star Wars Story_t05.mkv
AV synchronization issues were found in file 'Z:/Scratch/Rogue One- A Star Wars Story_t06.mkv' (title #7)
AV sync issue in stream 5 at 0:00:00 : Forced subtitles track #5 turned out to be empty and was removed from output file
Encountered 13 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Encountered 947 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
3 titles saved, 4 failed
Post by dcoke22 » Thu May 02, 2024 7:54 pm
Messages like the above generally indicate the drive is having a hard time correctly reading the optical disc. As Rojma has suggested, the standard advice is to gently clean the disc and try again.
