BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
Greetings Coopervid,
Lucky 2 get the BDR-XS07S w/ 1.01 today.
May I please have the info to flash and enable UHD?
Read your PM.stoggi wrote: Sat Apr 27, 2024 12:37 pm Hi Coopervid,
I also got a Pioneer BDR-XS07 with Firmware 1.01.
Can you please send me a PM with the Informations to upgrade?
Thank you so much![]()
U2.Signature wrote: Wed May 01, 2024 5:24 pm Greetings Coopervid,
Never heard of XS06. Do you mean XD06?
its a thing https://www.pioneerelectronics.com/PUSA ... s/BDR-XS06
but i dont think there is any fw to enable UHD for it as its slot load and no UHD version of it
Hello Coopervid,
here is my info:
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number: xxx
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 19
Drive platform: RS8E20
Firmware version: 1.01
Could you send me the Instructions aswell?
Many thanks!
here is my info:
OS device name: G:
Revision: 1.01
Serial number: xxx
Many thanks!
OS device name: H:
Product: BD-RW BDR-XS06
Revision: 1.01
Serial number: OJDL00XXXXXX
Firmware date: 2015-03-24
Drive platform: RS8721
Firmware name: PIONEER BDR-XS06
It's unfortunate that Pioneer produces quality drives but restricts users from backing up their own data. I fail to understand the benefits they obtain other than reduced sales and increased returns.
Thank you again for your help with the XS07.
Sent.readon wrote: Fri May 03, 2024 8:43 am Hello Coopervid,
here is my info:
OS device name: G:
Revision: 1.01
Serial number: xxx
Many thanks!
could you please send me the instructions to downgrade the XS07U to a libredrive firmware ?
kinodertoten
I've been holding onto a Pioneer drive for a bit, would it be possible to flash it to read UHD?
OS device name: F:
Product: BD-RW BDR-XS07U
Revision: 1.01
Serial number: TKDL0*****UC
Highest AACS version: 68
Drive platform: RS8E21
Firmware version: 1.01/ID05
Thank you,
OS device name: F:
Revision: 1.01
Thank you,
Post your Makemkv information.craxedunt wrote: Fri May 10, 2024 12:50 pm could you please send me the instructions to downgrade the XS07U to a libredrive firmware ?
Yours should be already UHD capable. Did you ever try?kinodertoten wrote: Sun May 19, 2024 4:27 pm I've been holding onto a Pioneer drive for a bit, would it be possible to flash it to read UHD?
OS device name: F:
Revision: 1.01
Thank you,
kinodertoten
Indeed, it worked. I had tried a while back with no luck and that was when the word on Pioneer drives was a firm "maybe in the future" so I had assumed I would be waiting a while. UHD rip was flawless, cheers!
I need some assistance with this drive too. It refuses to rip UHD discs in MakeMKV.
OS device name: I:
Revision: 1.03
Serial number: [redacted]
Firmware date: 2023-01-06
Highest AACS version: 76
Firmware version: ID05
OS device name: I:
Revision: 1.03
