dump for uhd 4k MKB20_v77_Transformers-_Rise_of_the_Beasts_92D0 send
thnx for adding
Re: MKB20_v77_Transformers-_Rise_of_the_Beasts_92D0
This movie has been out for several months. I'm surprised there isn't already a key for your disc. Are you sure your system is downloading the hashed keys? Are you getting the download HK disabled message or any other errors in the log?pyxis wrote: Wed May 01, 2024 12:44 pm dump for uhd 4k MKB20_v77_Transformers-_Rise_of_the_Beasts_92D0 send
thnx for adding
Thank you for pointing me into this area. I have a registered / paid version of MakeMKV, I had internet access enabled. I had not had any troubles with any disc before. I would never have assumed there was a problem at my end...Now I enabled the extended log info. I found "DEBUG: Code 0 at wOavELqC2=E/?z0D:213132721" and with a search on this forum I could fix the not getting this file in some way.
Would be great to have a error message from the MAKEMKV program.
I have this disc working now. thnx!
