Suzume (2022) Bonus Disc Debug Code
TheL1GHTSiDE
Post by TheL1GHTSiDE » Wed May 01, 2024 1:20 am
The feature film disc ripped fine but the bonus disc produced a debug code. I thought I would be helpful and post the log file.
Debug log started at Wed May 01 00:40:56 2024 , written by MakeMKV v1.17.6 win(x64-release)
001005:0000 MakeMKV v1.17.6 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Zachary/MakeMKV_log.txt
DEBUG: Code 3 at (Fjq;j%;wku%(|]PM?.".JoL:29395310
SDF  v098: PIONEER_BD-RW___BDR-S13U_1.03_DBDL930486UC
001011:0000 Using LibreDrive mode (v01.0 id=DFE22909F92F)
DEBUG: Code 2147483648 at WKYQi`r2nRn]/W8S:121265499
DISCID=16A53D304D1642962CB7D0204001E5A92408DA10
003307:0000 File 00012.mpls was added as title #0
003307:0000 File 00013.mpls was added as title #1
003307:0000 File 00014.mpls was added as title #2
003307:0000 File 00015.mpls was added as title #3
003307:0000 File 00017.mpls was added as title #4
003307:0000 File 00018.mpls was added as title #5
003307:0000 File 00020.mpls was added as title #6
003307:0000 File 00022.mpls was added as title #7
003307:0000 File 00023.mpls was added as title #8
003025:0000 Title #00003.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 7 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 8 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00041.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00000.m2ts was added as title #9
003025:0000 Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00025.m2ts was added as title #10
003307:0000 File 00028.m2ts was added as title #11
003307:0000 File 00030.m2ts was added as title #12
003025:0000 Title #00033.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00034.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00035.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00036.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00037.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00038.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00039.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00040.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
005014:0000 Saving 13 titles into directory file://D:/Movie Rips/Suzume_Disc2
001003:0020 DEBUG: Code 3221225489 at (Fjq;j%;wku%(|]PM?.".JoL:121262371
001003:0020 DEBUG: Code 3221225489 at =a$)zM@!&N!1NmNa:213130559
001003:0020 DEBUG: Code 3221225489 at ^~E}#@`T8tSTx=mT~:213129961
THDSF: [truehd @ 00000291F9A2AB10] End of stream indicated.
004007:0010 AV synchronization issues were found in file 'file://D:/Movie Rips/Suzume_Disc2/Suzume_Disc2_t00.mkv' (title #1)
004047:0010 AV sync issue in stream 4 at 0:00:00 : Forced subtitles track #4 turned out to be empty and was removed from output file
THDSF: [truehd @ 00000291FA03B7E0] End of stream indicated.
004007:0010 AV synchronization issues were found in file 'file://D:/Movie Rips/Suzume_Disc2/Suzume_Disc2_t01.mkv' (title #2)
THDSF: [truehd @ 00000291F9D5E440] End of stream indicated.
004007:0010 AV synchronization issues were found in file 'file://D:/Movie Rips/Suzume_Disc2/Suzume_Disc2_t02.mkv' (title #3)
THDSF: [truehd @ 00000291F92619F0] End of stream indicated.
004007:0010 AV synchronization issues were found in file 'file://D:/Movie Rips/Suzume_Disc2/Suzume_Disc2_t03.mkv' (title #4)
THDSF: [truehd @ 00000291FA4FA620] End of stream indicated.
004007:0010 AV synchronization issues were found in file 'file://D:/Movie Rips/Suzume_Disc2/Suzume_Disc2_t04.mkv' (title #5)
THDSF: [truehd @ 00000291F9CD70D0] End of stream indicated.
004007:0010 AV synchronization issues were found in file 'file://D:/Movie Rips/Suzume_Disc2/Suzume_Disc2_t05.mkv' (title #6)
THDSF: [truehd @ 00000291F9942F50] End of stream indicated.
FFMIX001: [FFM_AudioMix @ 000000F7A4FFBCF0] audio_mix: stereo to mono
FFMIX001: [FFM_AudioMix @ 000000F7A4FFBCF0] matrix size: 2 x 1
FFMIX001: [FFM_AudioMix @ 000000F7A4FFBCF0]   0.500   0.500
FFDEC000: [truehd @ 00000291F99426B0] End of stream indicated.
DEBUG: Code 0 at X1\<3JH#7DamPlL^:29402210
THDSF: [truehd @ 00000291F9FF3A90] End of stream indicated.
FFDEC000: [truehd @ 00000291F9FF6E50] End of stream indicated.
AV sync issues in D:/Movie Rips/Suzume_Disc2/Suzume_Disc2_t06.mkv
AV sync in 2 at 0:03:47.894 (8.666ms) : encountered overlapping frame, audio skew is +9.666ms
THDSF: [truehd @ 00000291F9FF5D10] End of stream indicated.
THDSF: [truehd @ 00000291F9AAF730] End of stream indicated.
THDSF: [truehd @ 00000291F93BE6D0] End of stream indicated.
004007:0010 AV synchronization issues were found in file 'file://D:/Movie Rips/Suzume_Disc2/Suzume_Disc2_t09.mkv' (title #10)
004047:0010 AV sync issue in stream 6 at 0:00:00 : Forced subtitles track #6 turned out to be empty and was removed from output file
THDSF: [truehd @ 00000291FAAC3420] End of stream indicated.
004007:0010 AV synchronization issues were found in file 'file://D:/Movie Rips/Suzume_Disc2/Suzume_Disc2_t10.mkv' (title #11)
THDSF: [truehd @ 00000291FA783830] End of stream indicated.
004007:0010 AV synchronization issues were found in file 'file://D:/Movie Rips/Suzume_Disc2/Suzume_Disc2_t11.mkv' (title #12)
THDSF: [truehd @ 00000291F9C2F0F0] End of stream indicated.
004007:0010 AV synchronization issues were found in file 'file://D:/Movie Rips/Suzume_Disc2/Suzume_Disc2_t12.mkv' (title #13)
005005:0080 13 titles saved
005036:0104 Copy complete. 13 titles saved.
Re: Suzume (2022) Bonus Disc Debug Code
Post by Woodstock » Wed May 01, 2024 1:37 am
The important thing is the part at the bottom:
If there had actually been a failure, it would be reported here.
chip2ner
Post by chip2ner » Thu May 16, 2024 7:23 am
Not necessarily true.I've had discs that gave me debug codes that ultimately successfully ripped with no error message, but were broken/corrupted during playback.
Post by dcoke22 » Thu May 16, 2024 7:35 am
Were they DVDs or a blu-ray? As I understand it, MakeMKV uses the content hash table that's part of the blu-ray specification to verify that what it reads from the blu-ray is a correct copy of what's on the disc. The output MakeMKV produces from a blu-ray (or UHD) should be 'correct' copy of what's on the disc. The file could, of course, become corrupted afterwards as part of a botched file copy or a hard drive with a bad sector and there's nothing MakeMKV can do about that.
DVDs don't have a content hash table that MakeMKV can use to verify that what is read from the disc is correct. I don't know exactly what MakeMKV does to verify DVDs, but I think it is more of a best effort sort of thing.
chip2ner
Post by chip2ner » Tue Jul 02, 2024 7:21 pm
Blu-rays. I've ripped over 300 discs and some of them have had scratches or spots where MakeMKV has to retry reading the section, ultimately failing to do so but it continues ripping anyway. The result is a file with corrupted video/audio, sometimes you can't even tell until you watch through it. I know for a fact it's not due to a faulty drive/bad sectors as the same disc will give me the same errors upon multiple rips to multiple drives...
I learned later that it may be due to my LG drive. LG has a "feature" that allows seamless playback of discs with scratches by sending dummy data (from what I understand) instead of reporting an error. Probably a nice feature for Blu-ray playback but sucks for ripping. I've found more success making a full disc backup, as hash check errors seem to be reported correctly when I do that.
