DylanValenti
#9916 Post by DylanValenti » Sun Apr 28, 2024 12:33 am
Are you able to transfer levels from a cmv4.0 rpu to a cmv2.9 rpu? Or is that not possible yet?
#9917 Post by RESET_9999 » Sun Apr 28, 2024 12:24 pm
You can only copy levels that already exist in the original RPU. So you cannot add a cmv4.0 bloc to a cmv2.9 rpu.
kazuma
#9918 Post by kazuma » Mon Apr 29, 2024 8:26 am
what is cmv4.0 and cmv2.9 exactly?
anta777
#9919 Post by anta777 » Mon Apr 29, 2024 7:10 pm
Good evening, RESET.
where does the release The Point Break 2015 DV-8 belong?
Red or green or yellow ?
sw5163
#9920 Post by sw5163 » Tue Apr 30, 2024 3:02 am
https://professionalsupport.dolby.com/s ... uage=en_US
DV P5 are getting harder and harder to find on BT sites these days. :(
morbius
#9921 Post by morbius » Tue Apr 30, 2024 9:47 am
so before buying a new TV, is there a need to check for CMv4 support? I've not seen a spec sheet that goes to that level of detail.
#9922 Post by RESET_9999 » Tue Apr 30, 2024 10:55 am
both the 1991 and 2015 have retail FEL DV from the bluray disc.
They don't make new TVs with older cmv2.9 chip anymore. So any TV after 2019 is most likely cmv4.0
anta777
#9923 Post by anta777 » Tue Apr 30, 2024 3:41 pm
Dear RESET.
Point Break (2015) have brightness what get expanded via FEL?
anta777
#9924 Post by anta777 » Tue Apr 30, 2024 4:07 pm
The Green Mile 1999 DV-8 what grade/master check?
H4537H
#9925 Post by H4537H » Tue Apr 30, 2024 5:20 pm
Following the CoreElect Dolby Vision development with great excitement.
Can someone please explain the difference between Profile 7 Dolby Vision DTDL FEL vs STDL FEL?
Have I understood correctly that a UHD disc with Profile 7 DTDL FEL remuxed to mkv with Profile 7 STDL FEL is a lossless conversion? And that the dual-track dual-layer FEL of the UHD are just "merged" into one single-track dual-layer FEL? And if the conversion is lossless, is it also possible to do the conversion the other way? (STDL -> DTDL).
Asking because I'm thinking about replacing my old OPPO UDP-203 (playing BDMV structures today) and I'm wondering if I get the exact same quality from converting UHD BDMV backups to mkv's and using an UGOOS instead?
Thanks in advance :-)
#9926 Post by RESET_9999 » Tue Apr 30, 2024 7:59 pm
yes:
PQ: https://slow.pics/c/jOvJUSbf
Plot: https://slow.pics/c/BaRgRP7w
Dear RESET.
Green mile is ok
#9927 Post by RESET_9999 » Tue Apr 30, 2024 8:02 pm
yes it's the same quality. It's just two different ways of muxing profile 7.
kazuma
#9928 Post by kazuma » Wed May 01, 2024 6:58 pm
Is cmv4.0 and cmv2.9 supported by ugoos? And is the plex app getting a update via internet or does it get only updated with the new version of coreelec?
#9929 Post by RESET_9999 » Wed May 01, 2024 7:23 pm
Of course, it supports the latest CM version.
Ugoos + Coreelect is KODI only. There's no PLEX app but you can use an addon that will give you access to your PLEX library but the app playing the movies is always KODI.
morbius
#9930 Post by morbius » Wed May 01, 2024 9:12 pm
[/quote]
thanks for the follow-up. So might older players like the Panny UP-BD820 and Oppo 203 be only CM v2.9, or does this really only matter at the display end of the chain?
