Good day everyone.
I submitted by email 5 days ago and still no luck. I’m new to this, it’s my second 4K rip. Should I wait longer or it simply won't work with my drive? Thank you!
MKB20_v76_Dune_94E9.tgz
Dump submitted for Dune 2021
Re: Dump submitted for Dune 2021
Wait longer. It might take a couple of weeks.
There are a bunch of Dune (2021) threads: https://forum.makemkv.com/forum/viewtopic.php?p=145541#p145541
I don't see that anyone else has posted your exact dump.
There's a UHD FAQ if you want to read more about the process. The hashed keys section is the most relevant.
Marshalljon
Happy to report it is now working ! Thx
amanofcharacter
Did you do anything to make it work? I've been having the same issue. I had messages in the MakeMKV log saying my auto-downloading of the HK table was disabled or not allowed. I followed steps to remedy that such as disabling Geo-Blocking in my Unifi router settings, using a VPN, disabling my firewall temporarily. Not sure which did it, but I don't see that error anymore.
However, I still simply get the "volume key is unknown for this disc - video can't be decrypted" error.
Thanks.
