DylanValenti
Post by DylanValenti »
Are you able to transfer levels from a cmv4.0 rpu to a cmv2.9 rpu? Or is that not possible yet?
You can only copy levels that already exist in the original RPU. So you cannot add a cmv4.0 bloc to a cmv2.9 rpu.
kazuma
Post by kazuma »
what is cmv4.0 and cmv2.9 exactly?
anta777
Post by anta777 »
Good evening, RESET.
where does the release The Point Break 2015 DV-8 belong?
Red or green or yellow ?
sw5163
Post by sw5163 »
kazuma wrote:
Mon Apr 29, 2024 8:26 am
https://professionalsupport.dolby.com/s ... uage=en_US
DV P5 are getting harder and harder to find on BT sites these days. :(
morbius
Post by morbius »
so before buying a new TV, is there a need to check for CMv4 support? I've not seen a spec sheet that goes to that level of detail.
anta777 wrote:
Mon Apr 29, 2024 7:10 pm
both the 1991 and 2015 have retail FEL DV from the bluray disc.
morbius wrote:
Tue Apr 30, 2024 9:47 am
They don't make new TVs with older cmv2.9 chip anymore. So any TV after 2019 is most likely cmv4.0
anta777
Post by anta777 »
Dear RESET.
Point Break (2015) have brightness what get expanded via FEL?
anta777
Post by anta777 »
The Green Mile 1999 DV-8 what grade/master check?
H4537H
Post by H4537H »
Following the CoreElect Dolby Vision development with great excitement.
Can someone please explain the difference between Profile 7 Dolby Vision DTDL FEL vs STDL FEL?
Have I understood correctly that a UHD disc with Profile 7 DTDL FEL remuxed to mkv with Profile 7 STDL FEL is a lossless conversion? And that the dual-track dual-layer FEL of the UHD are just "merged" into one single-track dual-layer FEL? And if the conversion is lossless, is it also possible to do the conversion the other way? (STDL -> DTDL).
Asking because I'm thinking about replacing my old OPPO UDP-203 (playing BDMV structures today) and I'm wondering if I get the exact same quality from converting UHD BDMV backups to mkv's and using an UGOOS instead?
Thanks in advance :-)
yes:
PQ: https://slow.pics/c/jOvJUSbf
Plot: https://slow.pics/c/BaRgRP7w
anta777 wrote:
Tue Apr 30, 2024 3:41 pm
Dear RESET.
Green mile is ok
anta777 wrote:
Tue Apr 30, 2024 4:07 pm
H4537H wrote:
Tue Apr 30, 2024 5:20 pm
yes it's the same quality. It's just two different ways of muxing profile 7.
kazuma
Post by kazuma »
Is cmv4.0 and cmv2.9 supported by ugoos? And is the plex app getting a update via internet or does it get only updated with the new version of coreelec?
Of course, it supports the latest CM version.
Ugoos + Coreelect is KODI only. There's no PLEX app but you can use an addon that will give you access to your PLEX library but the app playing the movies is always KODI.
morbius
Post by morbius »
[/quote]
thanks for the follow-up. So might older players like the Panny UP-BD820 and Oppo 203 be only CM v2.9, or does this really only matter at the display end of the chain?
