Beasts of the Southern Wild Fails
Looks like it needs a new SVQ file. Log file attached
- MakeMKV_log.txt
- (1.56 KiB) Downloaded 591 times
- Contact:
Re: Beasts of the Southern Wild Fails
Please send the dump file to svq@makemkv.com
Saved BD+ dump file as C:\Users\Intel/.MakeMKV/dump_Beasts_of_the_Southern_Wild_4AF5B8BBCA533B90.tgzRe: Beasts of the Southern Wild Fails
The file was emailed. Is it normal to be this large (37MEG) ?
- Contact:
With latest BD+ versions - unfortunately yes.dtblair wrote:The file was emailed. Is it normal to be this large (37MEG) ?
The new SVQ worked. Thanks for the quick response. It must be a never ending battle
I really hope that necroposting is not against the rules here, I did read the FAQ and didn't see anything explicitly prohibiting it.dtblair wrote: Sat Dec 08, 2012 8:04 pm The new SVQ worked. Thanks for the quick response. It must be a never ending battle
However, I've sent my dump over to the email and didn't get a response. My dump is the exact same as the one listed in this forum with the same alphanumeric after the title.
I'm wondering, did you get a disk-specific SVQ, or should it have been built into the program by now? I don't know if it's my drive causing issues or if I should look elsewhere.
If anybody is available to help, that would be awesome. Thanks!
With modern MakeMKV, you should not get a dump to send in for a regular blu-ray. It should just work. Can you copy & paste the MakeMKV log in here?Robant85 wrote: Fri Apr 05, 2024 8:07 pm I really hope that necroposting is not against the rules here, I did read the FAQ and didn't see anything explicitly prohibiting it.
That's what I thought. So you want me to paste the log from the GUI, and not the dump, correct?
Debug log started at Mon Apr 08 18:49:29 2024 , written by MakeMKV v1.17.6 win(x64-release)
001005:0000 MakeMKV v1.17.6 win(x64-release) started
No SDF v098: HL-DT-ST_BD-RE__WH16NS40_1.04_211901041348_KL6K1LJ4259
DEBUG: Code 0 at JH[R]Q46'ck{tMypQ:29396253
DEBUG: Code 0 at SM@e63jNU)cu"$Qt:213136746
DEBUG: Code 3 at (Fjq;j%;wku%(|]PM?.".JoL:29395310
SDF id v098: HL-DT-ST_BD-RE__WH16NS40_1.04_211901041348_KL6K1LJ4259
DEBUG: Code 2147483648 at WKYQi`r2nRn]/W8S:121265499
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=esIb/amRZ6gs9eBQlNYC1zLUkW47+z/eUTK4dIJbHJKxWCdWjovQqWYF330gsCLOGT8742CxFafGZS5GvFN1rUimUBYlp7x6SjPQZqWS6cw/Bf0ZxoZtJnMFjuAjJRCXsZANUgdWl2diXBgQlQjN0EL4mU2hG/1VUw==
DCE=CzBQeB3RTUEgbpB+REJtT7zt0FEithEov9IChaqot93AjHowSNFVHzobqiw0M9tCSAh/mguP4FsHGnQLbGSZ77vkAjuy1qepKOrjc1ne+3JeslyaChqum2wpd+UbM/qj7EyJp5aokXXqvaFFMp/ZU+Ien+2DV5vhGw==
003317:0000 Loaded 736 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/generic.svq
SVQ: generic006 builtin/generic.svq
DEBUG: Code 6 at /RSNd~i0r3ObSt$iMh:213133756
Is your drive flashed to be a LibreDrive? On the first screen of MakeMKV, right after it starts up, on the right is some drive info. You can post that here.
Super delayed, sorry I was out of the country.
OS device name: E:
Product: BD-RE WH16NS40
Revision: 1.04
Serial number: KL6K1LJ4259
Firmware date: 2119-01-04 13:48
Highest AACS version: 76
Drive platform: MT1959Re: Beasts of the Southern Wild Fails
No worries.
It appears that your drive is not properly flashed to enable LibreDrive. If it was, the 'Status' would be enabled.
There's a post with instructions on how to flash your drive. Ultimate UHD Drives Flashing Guide
I can't say for certain if flashing your drive to enable LibreDrive will allow you to rip the disc in question. I don't have this disc. I also wasn't using MakeMKV back in 2012, so I don't know how it worked back then. I do know that these days, generally speaking, a modern LibreDrive capable drive can rip most discs without trouble.
