Super slooooooooooowwwww site
All topics related to functioning of this forum or MakeMKV website
Krawk
#1 Post by Krawk » Thu Apr 18, 2024 9:11 pm
Site is running very slow. Server issues? Site under attack?
No thank you, I don't need a lesson on how hops between me and the destination works. Just asking a simple question.
Radiocomms237
Re: Super slooooooooooowwwww site
#2 Post by Radiocomms237 » Thu Apr 18, 2024 11:52 pm
Really slow here this morning as well. Cloudflare says it's a host problem.
Radiocomms237
#3 Post by Radiocomms237 » Fri Apr 19, 2024 1:28 am
Now a couple of hours later and it seems to be back to its old self.
#4 Post by Billycar11 » Sun Apr 21, 2024 1:32 am
honestly starting to think it was an attack
user number were in the 700-900 range when it was slow at off peak hours.
the normal amount i usually see is 300-500
Rojma
#5 Post by Rojma » Thu Apr 25, 2024 10:41 pm
Same here. Site has been super slow for me for a couple of weeks. I am also using CloudFlare for DNS so maybe its CloudFlare related?
#6 Post by Woodstock » Fri Apr 26, 2024 12:07 am
Unfortunately, it depends on what "the other guys" are doing. It's possible that 700-900 "people" are simply reading EVERYTHING, one message at a time, indexing things, but the legitimate search engines are NOT doing that. I'm guessing some sort of attack is going on, but it isn't attempted posting of messages.
In total there are 660 users online :: 5 registered, 1 hidden and 654 guests (based on users active over the past 5 minutes)
Radiocomms237
#7 Post by Radiocomms237 » Sat Apr 27, 2024 12:00 am
Whatever the reason, it seems to be getting worse. It seems to be worst in the early morning and in the evening (UTC)...
Currently:
In total there are 677 users online :: 5 registered, 0 hidden and 672 guests (based on users active over the past 5 minutes)
Most users ever online was 4394 on Sun Oct 24, 2021 5:23 pm
#8 Post by dcoke22 » Sat Apr 27, 2024 4:26 am
I wonder, is it possible to rate limit how quickly a guest can click through on the forum? I don't know if that'll help and I don't want to make the site unusable for guests, but it is sorta unusable now.
I wonder if someone is very clumsily scraping the site to feed into a training set for a LLM?
#9 Post by Woodstock » Sat Apr 27, 2024 2:45 pm
Ooooo... an artificial intelligence engine for ripping disks? Interesting thought... Although, it would primarily be learning how to ask questions about disks that don't read properly, rather than how to get around that.
Rojma
#10 Post by Rojma » Thu May 02, 2024 6:02 pm
Site looks like its working ok again. Maybe problem was related to this?
viewtopic.php?f=1&t=33919
#11 Post by d00zah » Thu May 02, 2024 6:22 pm
Don't know that the outages were related, but saw this from the mods on another forum (there were a few) during the same period:
Just a quick post to apologise for the forum outage earlier today.
We were being bombarded by several search bots (ClaudeBot being the main culprit). The bots completely ignored the robots.txt file and pushed us way over our resources.
Radiocomms237
#12 Post by Radiocomms237 » Wed Jun 19, 2024 3:56 am
It's been good for six weeks but up to its old tricks again today...
I'm getting heaps of Error code 522's (Connection timed out) and Cloudflare says it's a Host problem, as before.
Doesn't seem to be especially busy...
In total there are 125 users online :: 7 registered, 0 hidden and 118 guests (based on users active over the past 5 minutes)
#13 Post by Woodstock » Wed Jun 19, 2024 1:16 pm
The site had a reset prior to the slowness setting in, based on the fact that it insisted I wasn't logged in. May be related, because the last time it did that, we had massive delays for several days.
Seems to be working "OK" now, FOR NOW. (grumble grumble grumble)
mas1701
#14 Post by mas1701 » Fri Jun 21, 2024 7:02 pm
Website speed really sucks. Lot's of timeouts today. Webmaster should consider setting up mirror(s) if main site can't cope with the demand.
tomaso
#15 Post by tomaso » Wed Jan 28, 2026 7:26 am
That’s a fair point, but even that “asking the right questions” part is where AI can actually add value. An AI-driven engine could learn patterns from thousands of failed or problematic rips and suggest optimal strategies automatically—different read speeds, error correction methods, drive-specific tweaks, or even when a disk is likely physically damaged beyond recovery. Over time, it’s less about magically bypassing bad media and more about reducing trial and error and making smarter decisions faster.
Zfort Group - to drive into tech, automation, on anything with a decent engine.
