Correct Title for BluRay of 2010 - The Year we Make Contact
acoop03
#1 Post by acoop03 » Thu Jan 04, 2018 1:06 pm
I am looking to see if anyone knows the correct title for the BluRay.
I see t00 and t01
yorgo
Re: Correct Title for BluRay of 2010 - The Year we Make Cont
#2 Post by yorgo » Thu Jan 04, 2018 1:25 pm
Is MakeMKV showing any differences between the two files, such as different audio languages, subtitles, chapter counts? Are the titles of different lengths? Ultimately, it's only two, you can rip both, compare sizes and time lengths, and/or playback to find the right one.
You may want to read up on playlist obfuscation, where literally hundreds of titles are available to MakeMKV, of which only one is correct, google it for more info. That's a serious problem. One, two, or three titles can (usually) easily be figured out.
#3 Post by Woodstock » Thu Jan 04, 2018 4:27 pm
Playlist obfuscation (dozens or hundreds of titles) is different from what you're seeing. When there are just a few, you are probably looking at language differences, or "director's cut" vs. "theatrical cut" versions.
When you click on each title in the left hand window, the INFO window will display the playlist file name. using "t01" and such can vary by what your settings for minimum title length - it's better to refer to the playlist file name.
NickF2
Re: Correct Title for BluRay of 2010 - The Year we Make Contact
#4 Post by NickF2 » Fri Apr 26, 2024 12:12 am
Based on the track list it would appear the difference is language. The t00 file is the Japanese language support. t01 is all other languages.
