I bought a copy of Days of Future Past on Blu-Ray. It will not load. I went to the library and checked out a copy and it is doing the same thing. I get a message about loading HK then I get this over and over...
The source file '/BDMV/STREAM/01952.m2ts' is corrupt or invalid at offset 0, attempting to work around
It has been working fine and I have the most recent version for MacOS.
Days of Future Past
Re: Days of Future Past
Probably the optical drive is having trouble reading the disc.
The standard advice is to gently clean the disc and try again.
If the drive is powered by USB, it might not be getting enough power. Make sure both USB plugs are plugged into high powered ports.
rustyowens
Debug log started at Thu Apr 18 19:06:16 2024 , written by MakeMKV v1.17.6 darwin(x64-release)
001005:0000 MakeMKV v1.17.6 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/mac/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.64.1/(SecureTransport) LibreSSL/2.8.3 (x86_64-apple-darwin19.0) , proxy server not set.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BP50NB40 1.03 SIM0121380045d" opened in OS access mode.
SDF v098: HL-DT-ST_BD-RE_BP50NB40_1.03_212005070917_SIM0121380045
DEBUG: Code 2317353435 at |6Pkl^,%^rTYEu-ee:121265246
DEBUG: Code 0 at |6Pkl^,%^rTYEu-ee:213133388
DEBUG: Code 1 at |6Pkl^,%^rTYEu-ee:213133388
DEBUG: Code 2 at |6Pkl^,%^rTYEu-ee:213133388
DEBUG: Code 3 at |6Pkl^,%^rTYEu-ee:213133388
DEBUG: Code 4 at |6Pkl^,%^rTYEu-ee:213133388
DEBUG: Code 5 at |6Pkl^,%^rTYEu-ee:213133388
DEBUG: Code 2317353435 at |6Pkl^,%^rTYEu-ee:29396943
DEBUG: Code 0 at WX<_NOE'^Y?:OlZ]:29401750
DEBUG: Code 2147483648 at G}\YxK&TCAV(>~(6:121265499
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=2s0iCVaEUA1b+pqkAeVVOU+uIkmw2ZM9ffwK6z/s/+aNa3gYaBq2EEblHJHMQuNk8hXII5dYIgPz4OnQ4lW0lCSs6mJlK37xqq1aTqrToFJlDZcEcifqXo4Ofa9n4b9P8NT+Ki3D7feQiR4kBrn//KlDPRV3x2gzuA==
001003:0020 DEBUG: Code 0 at G}\YxK&TCAV(>~(6:121267247
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/generic.svq
SVQ: generic006 builtin/generic.svq
001003:0020 DEBUG: Code 6 at LY9/O;fm#^oalHD".g:213133756
DEBUG: Code 0 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 1 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 2 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 3 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 4 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 5 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 6 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 7 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 8 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 9 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 10 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 11 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 12 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 13 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 14 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 15 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 16 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 17 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 18 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 19 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 20 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 21 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 22 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 23 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 24 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 25 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 26 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 27 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 28 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 29 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 30 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 31 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 32 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 33 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 34 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 35 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 36 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 37 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 38 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 39 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 40 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 41 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 42 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 43 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 44 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 45 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 46 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 47 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 48 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 49 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 50 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 51 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 52 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 53 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 54 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 55 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 56 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 57 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 58 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 59 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 60 at @&VI/J5HvhVzerw}:213137689
DEBUG: Code 61 at @&VI/J5HvhVzerw}:213137689-
rustyowens
OK, I had some more discs come in:
The Martian Blu Ray
Star Trek 2: Blu Ray
John Wick
None of them will load. I pulled out another blu ray (Now You see Me) and it loaded.
Sounds like it is an issue with the discs or how they are being read.
The Martian Blu Ray
John Wick
I would say drive power issue or bad drive.rustyowens wrote: ↑Wed Apr 24, 2024 7:56 pmOK, I had some more discs come in:
The Martian Blu Ray
John Wick
For power use both USB cable direct into the motherboard no front panel ones
Or buy a high powered USB hub
For bad drive the first thing to try is cleaning the laser on the bp50 that's extremely easy just eject the tray and clean them with a lint free cloth damp and then dry it.
rustyowens
If it is a bad drive then why do some discs work and some don't
Because different Blu-rays are actually different data density.rustyowens wrote: ↑Wed Apr 24, 2024 8:21 pmIf it is a bad drive then why do some discs work and some don't
Some are bd25 others are bd50 for UHD to goes up to bd100
So maybe it just won't read the higher density discs.
Sadly I have seen many more bad drives than I have seen bad discs
rustyowens
Is there anywhere to see the data density for these discs?Billycar11 wrote: ↑Wed Apr 24, 2024 8:31 pmBecause different Blu-rays are actually different data density.rustyowens wrote: ↑Wed Apr 24, 2024 8:21 pmIf it is a bad drive then why do some discs work and some don't
MakeMKV's first screen will show you details about the disc, including the number of layers and how much data is on the disc. Also, sites like blu-ray.com typically list disc info in their reviews.
https://www.blu-ray.com/movies/X-Men-Days-of-Future-Past-Blu-ray/72503/
^ that says it is a single, two layer disc, a BD-50.
https://www.blu-ray.com/movies/1917-4K-Blu-ray/259242/
^ that 4K UHD, however, comes on a BD-100, which is a triple layer disc.
