MastaG
Post by MastaG »
I still have one of these Oppo bluray player clones which is basically the same thing but without the disc-reader.
Perhaps somebody can recommend some good (FEL) movies where the DV really stands out and make a difference?
jayper
Post by jayper »
MastaG wrote:
Wed Apr 24, 2024 1:02 pm
This thread has a lot of useful information and catalogs 99% of the discs released with Dolby Vision: https://forum.blu-ray.com/showthread.php?t=276448
kazuma
Post by kazuma »
I don't now of chinoppo have a decent FEL support with mp4/ts movies. Nobody tested so far i think?
DV-MKV doesn't work on it.
jayper
Post by jayper »
kazuma wrote:
Wed Apr 24, 2024 2:28 pm
There's a link in RESET_9999's signature that breaks down DV support across several devices. Including the Oppo.
DylanValenti
Post by DylanValenti »
Hey RESET, is there a way to generate a P7 RPU with an xml file from resolve. Keeps defaulting to P8.1
DylanValenti wrote:
Sat Apr 27, 2024 10:00 am
Not directly but if you have the original P7 RPU and you used the original scene cuts, you can copy the metadata levels from your P8 RPU with workflow 2-6.
I did it a couple of times for some static P7 movies like Avatar.
Example: https://drive.google.com/file/d/12CPNlw ... drive_link
DylanValenti
Are you able to transfer levels from a cmv4.0 rpu to a cmv2.9 rpu? Or is that not possible yet?
You can only copy levels that already exist in the original RPU. So you cannot add a cmv4.0 bloc to a cmv2.9 rpu.
kazuma
Post by kazuma »
what is cmv4.0 and cmv2.9 exactly?
anta777
Post by anta777 »
Good evening, RESET.
where does the release The Point Break 2015 DV-8 belong?
Red or green or yellow ?
sw5163
Post by sw5163 »
kazuma wrote:
Mon Apr 29, 2024 8:26 am
https://professionalsupport.dolby.com/s ... uage=en_US
DV P5 are getting harder and harder to find on BT sites these days. :(
morbius
Post by morbius »
so before buying a new TV, is there a need to check for CMv4 support? I've not seen a spec sheet that goes to that level of detail.
anta777 wrote:
Mon Apr 29, 2024 7:10 pm
both the 1991 and 2015 have retail FEL DV from the bluray disc.
morbius wrote:
Tue Apr 30, 2024 9:47 am
They don't make new TVs with older cmv2.9 chip anymore. So any TV after 2019 is most likely cmv4.0
anta777
Post by anta777 »
Dear RESET.
Point Break (2015) have brightness what get expanded via FEL?
anta777
Post by anta777 »
The Green Mile 1999 DV-8 what grade/master check?
