MastaG
Post by MastaG » Wed Apr 24, 2024 1:02 pm
I still have one of these Oppo bluray player clones which is basically the same thing but without the disc-reader.
Perhaps somebody can recommend some good (FEL) movies where the DV really stands out and make a difference?
jayper
Post by jayper » Wed Apr 24, 2024 1:45 pm
This thread has a lot of useful information and catalogs 99% of the discs released with Dolby Vision: https://forum.blu-ray.com/showthread.php?t=276448
kazuma
Post by kazuma » Wed Apr 24, 2024 2:28 pm
I don't now of chinoppo have a decent FEL support with mp4/ts movies. Nobody tested so far i think?
DV-MKV doesn't work on it.
jayper
Post by jayper » Wed Apr 24, 2024 2:44 pm
There's a link in RESET_9999's signature that breaks down DV support across several devices. Including the Oppo.
DylanValenti
Post by DylanValenti » Sat Apr 27, 2024 10:00 am
Hey RESET, is there a way to generate a P7 RPU with an xml file from resolve. Keeps defaulting to P8.1
Post by RESET_9999 » Sat Apr 27, 2024 12:33 pm
Not directly but if you have the original P7 RPU and you used the original scene cuts, you can copy the metadata levels from your P8 RPU with workflow 2-6.
I did it a couple of times for some static P7 movies like Avatar.
Example: https://drive.google.com/file/d/12CPNlw ... drive_link
DylanValenti
Post by DylanValenti » Sun Apr 28, 2024 12:33 am
Are you able to transfer levels from a cmv4.0 rpu to a cmv2.9 rpu? Or is that not possible yet?
Post by RESET_9999 » Sun Apr 28, 2024 12:24 pm
You can only copy levels that already exist in the original RPU. So you cannot add a cmv4.0 bloc to a cmv2.9 rpu.
kazuma
Post by kazuma » Mon Apr 29, 2024 8:26 am
what is cmv4.0 and cmv2.9 exactly?
anta777
Post by anta777 » Mon Apr 29, 2024 7:10 pm
Good evening, RESET.
where does the release The Point Break 2015 DV-8 belong?
Red or green or yellow ?
sw5163
Post by sw5163 » Tue Apr 30, 2024 3:02 am
https://professionalsupport.dolby.com/s ... uage=en_US
DV P5 are getting harder and harder to find on BT sites these days. :(
morbius
Post by morbius » Tue Apr 30, 2024 9:47 am
so before buying a new TV, is there a need to check for CMv4 support? I've not seen a spec sheet that goes to that level of detail.
Post by RESET_9999 » Tue Apr 30, 2024 10:55 am
both the 1991 and 2015 have retail FEL DV from the bluray disc.
They don't make new TVs with older cmv2.9 chip anymore. So any TV after 2019 is most likely cmv4.0
anta777
Post by anta777 » Tue Apr 30, 2024 3:41 pm
Dear RESET.
Point Break (2015) have brightness what get expanded via FEL?
anta777
Post by anta777 » Tue Apr 30, 2024 4:07 pm
The Green Mile 1999 DV-8 what grade/master check?
