oharag
Post
by oharag » Wed Apr 24, 2024 1:32 am
jdwarwick wrote: ↑Fri Mar 15, 2024 8:14 am
Enabling the check box as root worked for me:
1-Open a Terminal window and type "sudo"
2-Control or right click on the MakeMKV app and select "Show package contents
3-Go to Mac OS folder and select the "makemkv" executable
4- Drop it into the Terminal window, hit return and enter your password
You should now be able to go to "Privacy & Security", select "App Management" and enable both "makemkv" and "MakeMKV". Then, in the integrations tab of MakeMKV you should be able to enable the integration.
Quit MakeMKV and reopen and the setting should have stuck.
Dude this worked for me. You da man. I have no clue how to use Terminal - rely on gurus like you to lead the way.
My only thoughts with your interactions - initially I had to also add Terminal to the Security App list and then quit Terminal (which also quit MakeMKV). The second time around it worked. I haven't rebooted - but both Handbrake and VLC radio buttons are checked even if I put Make MKV.
One question - does this actually work - I mean open HB and allow MKV to do all the decoding? Well I'm going to try right now.
Thanks again.
oharag
Post
by oharag » Wed Apr 24, 2024 1:36 am
oharag wrote: ↑Wed Apr 24, 2024 1:32 am
Thanks again.
So no - no it doesn't work for handbrake. I opened MKV thinking it needed to be open for this to work. I then opened HB and seated a DVD (that MKV can read). I got the same HB warning about copy protection - and said continue - HB tried and tried - but failed.
So does this actually work - has anyone got this to work?
I'm going to reboot and give it the college try again - will report back to you.
oharag
Post
by oharag » Wed Apr 24, 2024 1:43 am
oharag wrote: ↑Wed Apr 24, 2024 1:36 am
Thanks again.
Reboot didn't work. I SO WANTED THIS TO WORK. I love MakeMKV. It does a great job. Fast - seems to make a backup of everything I've thrown at it (which is like only 4 titles do far). I just wish it exported in Mp4!!!!
Has any gotten this MakeMKV - mods other apps (VLC and Handbrake) to work? Again - does it even work?
Hey MakeMKV - if you are listening please:
- allow for merging multiple files into one file - maybe allow for a pause between movie and additional content.
- please consider Mp4 - unless there is a licensing fee involved. For most mkv file format is great - for a Mac user - using Apple TV/iPhones/iPads - Mp4 is much better. AND Plex loves Mp4 as well.
oharag
Post
by oharag » Wed Apr 24, 2024 2:40 am
oharag wrote: ↑Wed Apr 24, 2024 1:43 am
Thanks again.
Well I never knew VLC could rip movies - you learn something everyday. So I tried VLC - after assigning mkv as decoder - and sure it seemed to work. But man it is slow - the interface and setup SUCKS. And in the end I got a Mp4 that is very slow to open in Quicktime - and I managed to get - what I believe - is all of the languages at once. It was disturbing - oh and playback is slow as well - almost intolerable. '=
ATM mkv rules the roost.
wibbl3
Post
by wibbl3 » Fri Jun 07, 2024 11:39 am
Since running makemkv from the command line solves this I made an Automator application. Literally just Run Shell Script /Applications/mmkv.app/Contents/MacOS/makemkv (I named my own app MakeMKV.app for convenience).
There is one very little thing, when it's run the Applications folder gets what looks like an empty progress bar beneath it; and the Applications folder bounces when MakeMKV is quit. Any workaround?
dburgstrom
Post
by dburgstrom » Fri Jun 21, 2024 1:57 pm
To jdwarwick: THANK YOU! Dragging the MakeMKV app from the application package contents to Terminal with the sudo command worked for me.
Telecart
Post
by Telecart » Thu Jul 04, 2024 12:33 am
Running as root didn’t work for me to get handbrake working on Ventura 13.6.1 on an M2 Pro Mac Mini.
Any other suggestions?
jdwarwick
Post
by jdwarwick » Thu Jul 04, 2024 6:03 am
Not sure why it would not work for Handbrake for you - I'm on Sonoma 14.5 and using the latest versions of VLC and Handbrake.
Recap: enable Terminal in App Management, and then run the the MakeMKV app (MakeMKV in Applications) and the executable (makemkv in the MacOS folder) as root, then go to App Management and enable them, and then to MakeMKV preferences and enable the integrations there.
Telecart
Post
by Telecart » Sun Jul 07, 2024 12:53 am
jdwarwick wrote: ↑Thu Jul 04, 2024 6:03 am
Got it. Step missing was enabling Terminal in App Management as well. Thanks!!
