[Attention devs] Disc compatibility regression?
pneumatic
Post by pneumatic » Tue Apr 23, 2024 2:15 pm
It appears something was changed in one of the releases which may be hurting disc compatibility, here are 3 reports from this month where rolling back to a previous version restored compatibility
viewtopic.php?f=7&t=33777
viewtopic.php?f=7&t=33933
viewtopic.php?p=152087#p152087
pneumatic
Re: [Attention devs] Disc compatibility regression?
Post by pneumatic » Tue Apr 23, 2024 5:32 pm
Well the OP in the second report has just now advised that it was a false alarm.
The first report is kind of ambiguous as the disc itself appears dodgy, so I wouldn't get too worried about it.
The third report is definitely legit though because I can reproduce it. So something was changed between 1.16.7 and 1.17.6 that has broken compatibility with discs published by Entertainment One. I suppose the next step is for me to try each release between the two versions until I reach the one that breaks it, then you should be able to look at the release notes and see what caused it. This could take some time...
Post by d00zah » Tue Apr 23, 2024 6:07 pm
According to the changelog, introduced in MakeMKV v1.17.0 (27.6.2022)
- A new, rewritten DVD engine - much better handling for discs with structure protection
Announced here: DVD opening modes - CellWalk, CellTrim, CellFull
To the best of my knowledge, this feature remains WIP. IIRC, people have had success w/ 'CellTrim' on problem discs.
pneumatic
Post by pneumatic » Wed Apr 24, 2024 3:59 am
Yep you're right, I've got success with 1.16.7 and the next version after that was 1.17.0 which is not compatible with this disc so whatever was introduced in 1.17.0 is breaking compatibility with these structure protected discs published by E One, and none of the cell modes resolve it.
MakeMKV v1.16.7 win(x64-release) started
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
IFO file for VTS #3 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #5 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #6 does not match one in IFO header.
IFO file for VTS #6 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #7 does not match one in IFO header.
IFO file for VTS #7 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #8 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #9 does not match one in IFO header.
IFO file for VTS #9 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #11 does not match one in IFO header.
IFO file for VTS #11 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #12 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #13 does not match one in IFO header.
IFO file for VTS #13 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #14 does not match one in IFO header.
IFO file for VTS #14 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #15 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #16 does not match one in IFO header.
IFO file for VTS #16 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #17 does not match one in IFO header.
IFO file for VTS #17 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #18 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #19 does not match one in IFO header.
IFO file for VTS #19 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #20 does not match one in IFO header.
IFO file for VTS #20 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #21 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #22 does not match one in IFO header.
IFO file for VTS #22 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #23 does not match one in IFO header.
IFO file for VTS #23 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #24 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #25 does not match one in IFO header.
IFO file for VTS #25 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #26 does not match one in IFO header.
IFO file for VTS #26 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #27 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #28 does not match one in IFO header.
IFO file for VTS #28 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #29 does not match one in IFO header.
IFO file for VTS #29 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #30 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #38 does not match one in IFO header.
IFO file for VTS #38 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #39 does not match one in IFO header.
IFO file for VTS #39 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #40 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #41 does not match one in IFO header.
IFO file for VTS #41 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #42 does not match one in IFO header.
IFO file for VTS #42 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #43 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #44 does not match one in IFO header.
IFO file for VTS #44 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #46 does not match one in IFO header.
IFO file for VTS #46 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #47 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #48 does not match one in IFO header.
IFO file for VTS #48 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #49 does not match one in IFO header.
IFO file for VTS #49 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #50 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #51 does not match one in IFO header.
IFO file for VTS #51 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #52 does not match one in IFO header.
IFO file for VTS #52 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #53 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #54 does not match one in IFO header.
IFO file for VTS #54 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #55 does not match one in IFO header.
IFO file for VTS #55 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #56 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #57 does not match one in IFO header.
IFO file for VTS #57 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #58 does not match one in IFO header.
IFO file for VTS #58 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #59 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #60 does not match one in IFO header.
IFO file for VTS #60 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #61 does not match one in IFO header.
IFO file for VTS #61 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #62 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #63 does not match one in IFO header.
IFO file for VTS #63 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #64 does not match one in IFO header.
IFO file for VTS #64 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #65 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #69 does not match one in IFO header.
IFO file for VTS #69 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #70 does not match one in IFO header.
IFO file for VTS #70 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #71 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #72 does not match one in IFO header.
IFO file for VTS #72 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #73 does not match one in IFO header.
IFO file for VTS #73 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #74 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #75 does not match one in IFO header.
IFO file for VTS #75 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #77 does not match one in IFO header.
IFO file for VTS #77 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #78 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #79 does not match one in IFO header.
IFO file for VTS #79 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #80 does not match one in IFO header.
IFO file for VTS #80 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #81 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #82 does not match one in IFO header.
IFO file for VTS #82 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #83 does not match one in IFO header.
IFO file for VTS #83 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #84 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #85 does not match one in IFO header.
IFO file for VTS #85 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #86 does not match one in IFO header.
IFO file for VTS #86 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #87 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #88 does not match one in IFO header.
IFO file for VTS #88 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #89 does not match one in IFO header.
IFO file for VTS #89 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #90 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #91 does not match one in IFO header.
IFO file for VTS #91 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #92 does not match one in IFO header.
IFO file for VTS #92 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #93 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #94 does not match one in IFO header.
IFO file for VTS #94 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #95 does not match one in IFO header.
IFO file for VTS #95 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #96 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Title #1 was added (1 cell(s), 0:00:16)
Title #2 was added (1 cell(s), 0:00:12)
Cells 2-end were skipped due to cell commands (structure protection?)
Title #4 was added (1 cell(s), 0:00:50)
Title #6 was added (1 cell(s), 0:02:28)
Title #17 was added (1 cell(s), 0:01:50)
Jumped to cell 2 from cell 2 due to cell commands (structure protection?)
Loop detected. Possibly due to unknown structure protection.
Title #34 was added (1 cell(s), 0:00:08)
Cells 21-end were skipped due to cell commands (structure protection?)
Title #45 was added (20 cell(s), 2:08:47)
Title #49 was added (1 cell(s), 0:00:16)
Title #59 was added (1 cell(s), 0:15:40)
Cells 3-end were skipped due to cell commands (structure protection?)
Title #61 was added (2 cell(s), 0:05:01)
Region setting of drive ASUS:DRW-24D5MT does not match the region of currently inserted disc, trying to work around...
MakeMKV v1.17.0 win(x64-release) started
IFO file for VTS #0 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Also I used up one of my region changes in Windows device manager to see if setting it to region 2 to match the disc had any effect and it did not (it says "region setting does not match" in the above log because I changed it back to region 1 as I'll be doing a ton of region 1 discs soon).
