Beginning of Avatar Way of Water chopped off
rosede
Post by rosede » Mon Apr 22, 2024 1:50 pm
I'm trying to rip "Avatar: The Way of Water". However, the first several minutes get chopped off. Any thoughts why?
rosede
Re: Beginning of Avatar Way of Water chopped off
Post by rosede » Mon Apr 22, 2024 2:10 pm
I just tried another rip. I see the following in the log:
Cells 1-6 were removed from title start
I'll re-run with debugging enabled.
rosede
Post by rosede » Mon Apr 22, 2024 2:48 pm
Debug didn't provide any additional information.
Anyone know why MakeMKV would remove the first six cells?
pneumatic
Post by pneumatic » Mon Apr 22, 2024 4:52 pm
What happens if you set preferences to "CellFull" and minimum title length to 0 seconds?
rosede
Post by rosede » Tue Apr 23, 2024 12:25 pm
pneumatic wrote: Mon Apr 22, 2024 4:52 pm What happens if you set preferences to "CellFull" and minimum title length to 0 seconds?
Thank you for the suggestion, however, that did not work. The first six cells were still removed from the start.
pneumatic
Post by pneumatic » Tue Apr 23, 2024 1:40 pm
rosede wrote: Tue Apr 23, 2024 12:25 pm Thank you for the suggestion, however, that did not work. The first six cells were still removed from the start.
What happens if you go into manual mode and paste this string in:
t:@1-@6
which supposedly means to only extract cells 1-6 from title t (replace t with the actual title number of the main movie which I don't know)
AmericaSL
Post by AmericaSL » Sat Aug 23, 2025 3:52 am
Did anyone ever find a solution for this? It's happening to me with a DVD. I can't find any way to get it to include the first 2 1/2 minutes. Thanks!
squirrelwrangler
Post by squirrelwrangler » Fri Oct 10, 2025 5:29 pm
Manual mode and specifying 18:@1-@145 worked for me.
