Beginning of Avatar Way of Water chopped off
rosede
Post by rosede » Mon Apr 22, 2024 1:50 pm
I'm trying to rip "Avatar: The Way of Water". However, the first several minutes get chopped off. Any thoughts why?
rosede
Re: Beginning of Avatar Way of Water chopped off
Post by rosede » Mon Apr 22, 2024 2:10 pm
I just tried another rip. I see the following in the log:
Cells 1-6 were removed from title start
I'll re-run with debugging enabled.
rosede
Post by rosede » Mon Apr 22, 2024 2:48 pm
Debug didn't provide any additional information.
Anyone know why MakeMKV would remove the first six cells?
pneumatic
Post by pneumatic » Mon Apr 22, 2024 4:52 pm
What happens if you set preferences to "CellFull" and minimum title length to 0 seconds?
rosede
Post by rosede » Tue Apr 23, 2024 12:25 pm
Thank you for the suggestion, however, that did not work. The first six cells were still removed from the start.
pneumatic
Post by pneumatic » Tue Apr 23, 2024 1:40 pm
What happens if you go into manual mode and paste this string in:
t:@1-@6
which supposedly means to only extract cells 1-6 from title t (replace t with the actual title number of the main movie which I don't know)
AmericaSL
Post by AmericaSL » Sat Aug 23, 2025 3:52 am
Did anyone ever find a solution for this? It's happening to me with a DVD. I can't find any way to get it to include the first 2 1/2 minutes. Thanks!
squirrelwrangler
Post by squirrelwrangler » Fri Oct 10, 2025 5:29 pm
Manual mode and specifying 18:@1-@145 worked for me.
