Failure to read Rocky & Bullwinkle Season 3 Discs 2-4 on 1.17.0+
sephirothkefka
Post by sephirothkefka »
I recently was ripping Rocky and Bullwinkle on 1.17.6 and they failed to not only open but failed to make ISOs immediately after mounting. Reverting back to 1.16.7 is perfectly fine. Here is the debug log:
Debug log started at Mon Apr 22 06:51:43 2024 , written by MakeMKV v1.17.6 win(x64-release)
001005:0000 MakeMKV v1.17.6 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Sephirothkefka/MakeMKV_log.txt
DEBUG: Code 3 at (Fjq;j%;wku%(|]PM?.".JoL:29395310
SDF  v098: PIONEER_BD-RW___BDR-211M_1.53_QHDL002509WL
No  SDF v098: HL-DT-ST_BD-RE__GGW-H20L_YL07_20110319123456_K1681ND5317
SDF id v098: HL-DT-ST_BD-RE__GGW-H20L_YL07_20110319123456_K1681ND5317
No  SDF v098: TOSHIBA_DVD/HD__X807616_MC08_6YJW047656
SDF id v098: TOSHIBA_DVD/HD__X807616_MC08_6YJW047656
No  SDF v098: Alcohol_V-SATA_CD/DVD_1.0d_20141027120000
DEBUG: Code 0 at JH[R]Q46'ck{tMypQ:29396253
DEBUG: Code 0 at SM@e63jNU)cu"$Qt:213136746
SDF id v098: Alcohol_V-SATA_CD/DVD_1.0d_20141027120000
DEBUG: Code 1 at MLcC`m@J,u_zIjQA5:121263199
DEBUG: Code 2 at MLcC`m@J,u_zIjQA5:121263199
DEBUG: Code 3 at MLcC`m@J,u_zIjQA5:121263199
DEBUG: Code 4 at MLcC`m@J,u_zIjQA5:121263199
Launching C:\Program Files (x86)\MakeMKV\mmgplsrv64.exe
001003:0020 DEBUG: Code 118095996 at 0`Ya?1$!|%$JJIlO4"I>U-z:29394183
001003:0020 DEBUG: Code 0 at 0`Ya?1$!|%$JJIlO4"I>U-z:121263590
001003:0020 DEBUG: Code 48939 at _y<{y.H`KydrY`/TJ{+d:213133250
001003:0020 DEBUG: Code 7 at _y<{y.H`KydrY`/TJ{+d:121265062
001003:0020 DEBUG: Code 0 at _y<{y.H`KydrY`/TJ{+d:29394689
001003:0020 DEBUG: Code 3221225649 at LKu,[_<phG675tlGM#:cb<I:29394919
001003:0020 DEBUG: Code 3221225649 at 0`Ya?1$!|%$JJIlO4"I>U-z:213130145
001003:0020 DEBUG: Code 3221225480 at LKu,[_<phG675tlGM#:cb<I:121262509
001003:0020 DEBUG: Code 3221225480 at 0`Ya?1$!|%$JJIlO4"I>U-z:29394183
001003:0020 DEBUG: Code 0 at /u`0WKB|YXK!?|:29397104
Application exited at Mon Apr 22 06:51:55 2024
Anyone know whats going on? I feel like this is a niche issue as all other DVDs are perfect. This is a ClassicMedia/Sony Wonder title if it helps.
Re: Failure to read Rocky & Bullwinkle Season 3 Discs 2-4 on 1.17.0+
There are different DVD Opening modes. Maybe MakeMKV is getting confused with the default opening mode.
sephirothkefka
dcoke22 wrote: Tue Apr 23, 2024 4:39 am There are different DVD Opening modes. Maybe MakeMKV is getting confused with the default opening mode.
Okay that's very weird.
I tried auto which I didn't do earlier (instead of just CellWalk or CellTrim which both didn't work by themselves) and then it just worked straight away. Usually I prefer CellWalk by itself as it makes episodes easy to distinguish.
techRob
Post by techRob »
I was going to post about this same topic - I managed to get disc 2 to work (after multiple attempts), but 3 and 4 continually fail almost instantly (on 3 different drives).
However, I wanted to add - for the sake of "why not try something random" - I broke out DVD Decrypter, and was able to make an ISO of both disc 3 and 4.
With that said.... I did not know about the "DVD Opening Modes" feature and am going to play around with that.
sephirothkefka - thank you for making this thread
dcoke22 - thank you for pointing out the DVD Opening Modes
