Will be a great program!
TopGun2010
#1 Post by TopGun2010 » Fri Feb 06, 2009 9:21 pm
Great program, this will be a hit when it’s error free! Hopefully it will have a maximum price of USD 25.
I have three complains. First, it should be nice if you can select audio and subtitles stream for both DVD and Blu-ray disc and files on hard drive. Second, I use a Popcorn Hour A-110 for playing media files, it can’t use the subtitle structure: gives the next error: subtitle format not recognized. Third, it would be nice if you can set a compress mode for making a smaller MKV file.
Thanks for working on this program!! Hopefully it will be as great as DVD Shrink. :D
Re: Will be a great program!
#2 Post by mike admin » Sun Feb 08, 2009 7:50 am
Hi TopGun,
TopGun2010 wrote:Great program, this will be a hit when it’s error free! Hopefully it will have a maximum price of USD 25.
First of all-thank you!
I'm not sure whether I understand what you mean, sorry. You could always select audio and subtitles track in every title by expanding it and choosing the ones you need.
Do you have this problem with DVD or BluRay? If it's DVD it's very strange- it should work. The format of BluRay subtitles is new, so it may happen that Popcorn doesn't support it yet.
MakeMKV does not change audio/video data during conversion at all. Soit is impossible to change output size since it is determined by input size. But you could always re-encode MKV with different parameters and there are many free tools to do it.
Thank you!
TopGun2010
#3 Post by TopGun2010 » Tue Feb 10, 2009 6:12 pm
Hi Mike,
-with blu-ray, i have not tested with dvd, i will do this.
-OK, thanks for your help.
TopGun2010
Private messageWebsite
TopGun2010
#4 Post by TopGun2010 » Wed Feb 11, 2009 2:09 pm
Hi Mike,
Also with DVD, Popcorn Hour A-110 displays: Subtitle Format Not Supported
Maybe with new firmware (this month) it works.
Greetings
doubledrat
#5 Post by doubledrat » Thu Sep 03, 2009 8:21 am
I've just downloaded the latest version and I too have this problem with the popcorn hour A100. "Subtitle Format Not Supported"
any idea why?
ChinaJade
#6 Post by ChinaJade » Thu Sep 03, 2009 4:34 pm
@TopGun2010
Your second issue...
The PGS subtitle format of BluRays is indeed currently not supported by the Popcorn 1xx family (as of firmware version 01-17-090204-15-POP-403-000, the latest as of this writing).
The problem with subtitles on BluRays lies with the Popcorn units, and not with MakeMKV.
cheers,
CJ
kryzchek
#7 Post by kryzchek » Thu Sep 03, 2009 8:14 pm
The Popcorn Hour has never supported VOBSUB/IDX subtitles embedded within an MKV. This is a well known and not related to MakeMKV.
Bling2Ming
#8 Post by Bling2Ming » Thu Sep 03, 2009 11:25 pm
mkvextract (a part of the mkvtoolnix suite) will pull embeded vobsub/idx files out of the mkv container in less than 2 minutes on my machine. I don't know about the popcorn-hour but my WD-TV reads the extracted external vobsub files perfectly.
The syntax for extracting vobsub subtitles with mkvextract (assuming subs are the 3rd track) is below.
mkvextract tracks your-movie.mkv 3:your-movie.sub
This will extract two files:- your-movie.idx and your-movie.sub
As long as the filenames are the same as the movie name the WD-TV sees the subs and displays them fine.
Note: It's easy to acertain the track number with Mediainfo
There is a GUI for mkvextract available but I've never needed it. you can get that here. http://coreforge.org/projects/mkvextractgui/
doubledrat
#9 Post by doubledrat » Fri Sep 04, 2009 8:19 am
thanks for the pointers guys.
just to clarify (I should have said this initially), I'm mkv-ing a DVD, not a bluray. Does the same still apply i.e. it's a VOBSUB/IDX issue?
kryzchek
#10 Post by kryzchek » Fri Sep 04, 2009 4:54 pm
doubledrat wrote:thanks for the pointers guys.
Correct. The Popcorn Hour firmware to support vobsub/idx subtitles embedded within MKVs has been in BETA testing since about February. Hopefully it will be released soon. You will need to embed a different format of subtitle within the MKV.
