PlainSimpleTailor
Post by PlainSimpleTailor » Mon Apr 15, 2024 8:53 am
Hello all!
I've been lurking here for a bit, checking out the various drives, figuring out just how deep I want to get into this entire process, and decided I might as well make it official and create an account. It's only been about two weeks since I started ripping my Blu-Rays, and it's really awesome how MakeMKV is pretty easy to use.
I was just wondering: I looked around a bit but was unable to find any sort of general chat area, does that not exist? It's cool if it doesn't, I just thought it'd be nice to do something other than only ask questions, ask for help, etc. It can sometimes be a little intimidating joining a community like this.
Anyway, that was all, I'll shut up now!
Mikeismad
Post by Mikeismad » Tue Apr 16, 2024 1:49 am
I don’t understand why Alex Coluzzi (alexcoluzzi32@gmail.com) is not mentioned as a seller of drives. I feel like he used to be the only person listed. I’ve bought several drives from Alex and he’s always been available when I had a question.
iam2diezel
Post by iam2diezel » Tue Apr 16, 2024 7:12 pm
Mikeismad wrote: Tue Apr 16, 2024 1:49 am I don’t understand why Alex Coluzzi (alexcoluzzi32@gmail.com) is not mentioned as a seller of drives. I feel like he used to be the only person listed. I’ve bought several drives from Alex and he’s always been available when I had a question.
believe he goes by Jonghotti and has his own thread on this forum here.
runnn
Post by runnn » Tue Apr 16, 2024 7:55 pm
I'm a bit unsure if my drive is able to be flashed. My model is the "BD-RE WH14NS40" but the instructions says "3. SVC NS50+ LG only on label for NB drives NB50+". I don't understand this and does that mean that my drive can't be flashed?
I have downloaded "The all you need firmware pack" and then followed the "How to Flash videos and commands" instructions. Everything went fine (see output)
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d E: rawflash enc -i C:\Users\run\Downloads\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file C:\Users\run\Downloads\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: HL-DT-ST_BD-RE__WH14NS40_1.03_211711211658_M69IC392244
 100% Operation finished
Done successfully
But in MakeMKV nothing has changed.
OS device name: E:
Product: BD-RE WH14NS40
Revision: 1.03
Serial number: M69IC392244
Firmware date: 2117-11-21 16:58
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.03
Could someone please tell me what I'm doing wrong - thanks
Post by Billycar11 » Tue Apr 16, 2024 10:24 pm
runnn wrote: Tue Apr 16, 2024 7:55 pm I'm a bit unsure if my drive is able to be flashed. My model is the "BD-RE WH14NS40" but the instructions says "3. SVC NS50+ LG only on label for NB drives NB50+". I don't understand this and does that mean that my drive can't be flashed?
Done successfully
OS device name: E:
Revision: 1.03
No enc
runnn
Post by runnn » Wed Apr 17, 2024 7:54 am
No enc
Thanks a million. May I ask what does it mean to have a non-encrypted firmware? How will affect my use of MakeMKV? Does it mean that I have no reason to flash the drive?
Post by Billycar11 » Wed Apr 17, 2024 7:27 pm
runnn wrote: Wed Apr 17, 2024 7:54 am
No enc
Yeah you don't have encrypted fw.
You still need to flash it
Does not change anything with makemkv
Tony359
Post by Tony359 » Fri Apr 19, 2024 3:52 pm
Hello all
I've had an Asus BC-12D2HT in my system for a while and by looking on this forum it's not clear whether I could flash it to read and rip 4K BD.
Below is the output of MakeMKV, can anybody point me to the right direction? (I believe I am not allowed to add pictures yet?)
OS device name: F:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.00
Serial number: SIK91G2QF134
Firmware date: 2115-12-09 11:47
Bus encryption flags: 1E
Firmware version: 3.00
BD raw metadata read: Partial
Thanks a lot!
Post by MartyMcNuts » Sat Apr 20, 2024 11:59 pm
Tony359 wrote: Fri Apr 19, 2024 3:52 pm Hello all
OS device name: F:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.00
Thanks a lot!
It can already read UHD discs. Just put one in and start ripping like normal.
Tony359
Post by Tony359 » Sun Apr 21, 2024 8:33 am
What!!! ahah amazing! I had no idea!
Thank you so much!
parisdoro
Post by parisdoro » Tue Apr 23, 2024 9:07 am
Hi, I have a "verbatim eu" Pioneer BDR-UD03 firmware 1.14 with BDXL icon on it. I try to read a UHD disc and it doesn't work. Is it possible to flash to make it recognize UHD discs and rip them?thanks
Enrique8712
Post by Enrique8712 » Tue Apr 23, 2024 6:38 pm
Hello, I've read this guide a couple of times but still feel a little confused because of how it is worded. Could someone help me? I just want to know which one I can buy right now and flash it and have it working? If anyone can help me with this, I would really appreciate the help! I don't want to buy the wrong one and have to keep returning them.
Post by d00zah » Tue Apr 23, 2024 7:20 pm
Enrique8712 wrote: Tue Apr 23, 2024 6:38 pm Hello, I've read this guide a couple of times but still feel a little confused because of how it is worded. Could someone help me? I just want to know which one I can buy right now and flash it and have it working? If anyone can help me with this, I would really appreciate the help! I don't want to buy the wrong one and have to keep returning them.
Start here:
Drives for sale, Flashing Services, where to buy...
Choose a buyer in your region & contact them via email (usually in the 1st post of the thread) about what you are looking for, current stock, etc..
lifesgucci
Post by lifesgucci » Mon Apr 29, 2024 12:47 pm
ack i found an lg WH14NS40 for $40 in a local store and didn't check the date. it's jan 2015. how borked am i? is it's possible to uhd flash or should i just leave it alone?
Post by d00zah » Mon Apr 29, 2024 1:10 pm
lifesgucci wrote: Mon Apr 29, 2024 12:47 pm ack i found an lg WH14NS40 for $40 in a local store and didn't check the date. it's jan 2015. how borked am i? is it's possible to uhd flash or should i just leave it alone?
Too old... just leave it alone. >Oct 2015 is the target.
