Big-rome
Post by Big-rome » Mon Apr 15, 2024 12:00 am
sultanmehmet wrote:
Sun Apr 14, 2024 7:08 pm
Big-rome wrote:
Sun Apr 14, 2024 5:08 pm
sultanmehmet wrote:
Sat Apr 13, 2024 5:41 pm
I got that. I know it's being worked on and I have a sony x700 to keep me satisfied for FEL playback while the software part of the AM8 gets optimized. I'll wait if need be, the development at CoreElec seems to have made great progress in the last few months so I'm pretty sure we'll get something working sooner rather than later. And if not then I can just act accordingly then. Am in no way in a hurry to get a streamer that works.
No work is being done on the AM8. S905X4-K doesn't support FEL. Also the AM6B+ is available on aliexpress $152 USD plus taxes and free shipping.
I know they're waiting on drivers and other things so it's in the queue. We tested the Nokia boxes extensively but sent them back to Amazon because one wouldn't start up anymore, so in the end it didn't really matter either way.
The AM6B+'s on Aliexpress for $152 I've found myself too but after you login they all become $184 or more (I have a CC limit of $175). Probably some deal for first time buyers that gets removed after you log in. If yours is a different one that stays at $152 I'll gladly take that deal.
UDPATE: Bit the bullet and bought an AM6B+ from Aliexpress for $190 including shipping by using afterpay :lol: . It was the cheapest I could get it from Aliexpress. Should arrive in about 2 weeks.
The seller PLAY TV has the cheapest price I found. $166.28 with tax and free shipping. Im waiting on my second AM6B+ now.
sultanmehmet
Post by sultanmehmet » Mon Apr 15, 2024 1:22 am
Ordering from Play TV would have cost me $192 all combined. I ordered it from Diffingle Store where it was a little bit cheaper. A second one, nice.
How is fast forwarding FEL movies? Does it crash in CoreElec while attempting to go to the next chapter or fast forwarding?
Big-rome
Post by Big-rome » Mon Apr 15, 2024 1:49 am
Next chapter and fast forwarding works great. Best player to have right now for local playback.
DylanValenti
Post by DylanValenti » Mon Apr 15, 2024 9:35 am
Any idea what's happening here?
Choice? [1,2,3,4,5,6,7,8,9]?9
-- This script export a timecode EDL file for Resolve from DV or HDR10plus source
-- You must have the Dolby Metafier in the tools folder
-- Input can be XML/RPU/MKV/M2TS/TS/MP4/HEVC/JSON
-- If input is not a video, the script assume it's 23.976 unless you add in the filename: '24FPS' '25FPS' '60FPS'
Drag and drop a DoVi file and press enter...Z:\Aliens\Extras\RPU.bin
04/15/2024/02:28:40.283000000 metafier: ERROR Incorrect filename range syntax
Traceback (most recent call last):
  File "Z:\[DoVi]\tools\EDL_maker.py", line 56, in <module>
    convert_frames_to_smpte(args.input, args.output, args.fps)
  File "Z:\[DoVi]\tools\EDL_maker.py", line 31, in convert_frames_to_smpte
    with open(input_file, 'r') as infile, open(output_file, 'w') as outfile:
FileNotFoundError: [Errno 2] No such file or directory: 'Z:\\[DoVi]\\temp.folder78\\shotlist.duration.txt'
The script has been completed. Do you want to quit or go back to main menu (q or m default=q)?
Post by RESET_9999 » Mon Apr 15, 2024 11:03 am
Not sure how many times I have to say it but:
''no space nor special characters in the script folder name and path!!! ''
dolby professional tool does not accept []
Z:\[DoVi]
DylanValenti
Post by DylanValenti » Mon Apr 15, 2024 11:28 am
Wow I’m an idiot lol. Thanks for the response🫡
dysprosium
Post by dysprosium » Thu Apr 18, 2024 6:56 am
RESET_9999 wrote:
Wed Apr 03, 2024 10:37 am
HDR10 playback is fine as long as your player doesn't tonemap DV to HDR10 like the x800m2/x700 can do when you have DV set to ''on'' and play a TS/M2TS rip.
Thanks for your response, one more question for you:
You've noted that P5 > P8 due to the colourspace being equivalent to 11.5-bit YCbCr > 10-bit YCbCr.
Is there a noticeable difference between P8 and P5, assuming that it's the same master/streaming quality, on consumer-grade 10-bit panels?
Similar to how there are certain FEL films e.g. Saving Private Ryan where the 12-bit BL+FEL+RPU has noticeable brightness/colour/quality differences compared to the 10-bit BL+RPU?
Sorry to ask you so many questions but you are truly the authority on all things DV!
Post by RESET_9999 » Thu Apr 18, 2024 10:56 am
Not really.
But any AppleTV webdl has some static color reshaping in the RPU which messes up the colors IMO.
You have plenty of P5 vs HDR10 BL comparisons here: https://docs.google.com/spreadsheets/d/ ... =917134052
Baer2021
Post by Baer2021 » Fri Apr 19, 2024 1:00 am
Hello - I'm running into an issue getting my UGOOS AM6B Plus to boot from the SD card once I've used Rufus to write the image on my PC, moved the correct .dtb file and renamed it along with changing the file extension to "dtb.img" and copied dovi.ko over. When I hold the recovery button it just goes to the Android boot screen and a couple of times it seems like it has tried to use the SD card but I just get a S922X logo that flashes on my screen before the device keeps power cycling itself. Has anyone run into this?
sw5163
Post by sw5163 » Fri Apr 19, 2024 2:17 am
Difference, yes. Noticeable, no.
https://www.avsforum.com/threads/dolby- ... 7.2930062/
10-bit panel can show 12-bit content with dithering, but at least for me, it's basically impossible to tell the difference when 10-bit content is properly implemented. However, Dolby FEL is also 4:2:2 sub-sampling. The difference between 4:2:2 and 4:2:0 can be noticed around high contrast edges.
razierklinge
Post by razierklinge » Fri Apr 19, 2024 2:47 am
For AM6B+/CoreELEC support, I'd ask here: https://discourse.coreelec.org/t/dolby- ... 24273/1320
But from my experience, what you described worked fine for me. I held the recovery button down until I saw the "CoreELEC" screen and then I was good to go.
gpmc01
Post by gpmc01 » Fri Apr 19, 2024 5:29 am
You should raise this issue in Coreelec Forum to get proper support.
kazuma
Post by kazuma » Tue Apr 23, 2024 11:22 am
what is a dual-track and dual-layer exactly? can someone describe in simple terms?
sw5163
Post by sw5163 » Wed Apr 24, 2024 2:45 am
Dolby Vision is really complicated, you may want to do more research to learn how it actually works.
sw5163 wrote:
Mon Jul 18, 2022 6:59 am
In human words:
BL(base layer): an HDR10 2160p YCbCr 4:2:0 10-bit video.
Dolby Vision fall back to this when not supported.
EL(enhancement layer): an HDR10 1080p YCbCr 4:2:0 10-bit video.
Supported device use BL and EL to mux a final 4:2:2 12-bit video.
RPU(reference processing unit): To indicate how filmmaker would like the video to be separately shown on 100nitSDR/600nit/1000nit/10000nit display. (despite the actual brightness record in BL)
There are basically 4 types of Dolby Vision video:
Profile 5(streaming): ICtCp 4:2:0 10-bit video + RPU.
It uses a more efficient color coding, but appear green and purple on non support device.
Profile 8.1: BL+RPU
Profile 8.4: Dolby Vision shot on iPhone, HLG BL+RPU
FEL(Full Enhancement Layer)
Profile 7 DT_DL FEL: BL in one video track, EL+RPU in another video track.
Profile 7 ST_DL FEL: BL+EL+RPU in one same video track.
MEL(Minimum Enhancement Layer)
Profile 7 MEL: BL+RPU same as 8.1 just in bluray container.
Please don't hesitate to point out my mistake!
MastaG
Post by MastaG » Wed Apr 24, 2024 1:02 pm
I still have one of these Oppo bluray player clones which is basically the same thing but without the disc-reader.
Perhaps somebody can recommend some good (FEL) movies where the DV really stands out and make a difference?
