Windows going to sleep during ripping
GetOutOfMySight
Post by GetOutOfMySight » Tue Mar 19, 2024 11:09 am
I have experienced Windows (11 23H2) going to sleep while ripping Blu Rays in my Verbatim 43888 (Pioneer BDR-UD04).
Windows is set to go to sleep after 15 minutes of inactivity.
I have checked
powercfg /requests
and it does not show any wake lock/request while MakeMKV is ripping.
So far, I am using PowerToys Awake to temporarily disable the usual sleep timeout while ripping.
Nonetheless, it would be more convenient if MakeMKV (or the disc drive being active) would keep Windows awake.
Is this a bug local to my setup or something MakeMKV does not do as of yet?
Radiocomms237
Re: Windows going to sleep during ripping
Post by Radiocomms237 » Tue Apr 16, 2024 3:01 am
As an aside, one quirk I've noticed is that, if working direct from disc when Windows goes to sleep, you lose your entire setup (naming tracks, etc). But if working from a backup, all your setup comes back up when Windows wakes up again!
What I did was to disable the automatic sleep timer in Windows altogether, for me, it was just more trouble than it was worth! You may find that there's a dedicated key on your keyboard that also puts Windows to sleep instead.
outlier
Post by outlier » Thu Apr 18, 2024 5:02 am
I had wondered if makemkv was implemented to call "PowerSetRequest(h, PowerRequestSystemRequired)" while is was processing a disc, and this thread seems to suggest 1) the answer is no, or 2) Microsoft has further increased/changed what's needed for a process to keep the system awake.
Previously an app only needed to call "SetThreadExecutionState(ES_SYSTEM_REQUIRED)", but then Microsoft thought too many programs were being written to keep the system alive and changed to a different API that has more explicit reference counting.
