ASUS BC-12D2HT
DaddyCool
ASUS BC-12D2HT
Post by DaddyCool »
Hi all,
Been looking at the beginning of the forum, can't seem to find which flash version I need for ASUS BC-12D2HT for UHD
I use DVDFAB passkey for decryption.
Any help would be appreciated...
Re: ASUS BC-12D2HT
DaddyCool wrote:
Wed Apr 17, 2024 2:04 pm
Hi all,
If you use DVDFab, then you need to use a non MK firmware version. Try looking at DVDFab's compatible drive/firmware list.
DaddyCool
Re: ASUS BC-12D2HT
Post by DaddyCool »
Thank you for the response,
So, If I flash DE_ASUS_BC-12D2HT_3.11_MK, I should then be able to downgrade to ASUS firmware 3.01 ?
Thanks in advance
Re: ASUS BC-12D2HT
DaddyCool wrote:
Mon Apr 22, 2024 10:35 am
Thanks in advance
Yes, you should be able to.
DaddyCool
Re: ASUS BC-12D2HT
Post by DaddyCool »
After a fewworrying momments, managed to flash it to 3.00
OS device name: E:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.00
Serial number: XXXXXXXXXXX
Firmware date: 2115-12-09 11:47
Bus encryption flags: 1E
Highest AACS version: 72
Firmware version: 3.00
BD raw metadata read: Partial
Should this be able to rip UHD's?
PS.. thanks for your helpwith this.....
DaddyCool
Re: ASUS BC-12D2HT
Post by DaddyCool »
All working. The first Dune UHD copied successfully. Makemkv, great product, purchasing now.
daman75
Re: ASUS BC-12D2HT
Post by daman75 »
DaddyCool wrote:
Mon Apr 29, 2024 9:55 pm
Hello, how did you manage to do this because I have Firmware version: 3.12 and I also need to downgrade to 3.00. Could you send a link to the post? I am asking you for help. Regards
