Bluray ripping error failure
sov8302
Post by sov8302 » Wed Apr 17, 2024 2:44 pm
Hello I was ripping my movies to back them up but having trouble with this particular movie Incredibles 2.
I have did a test making sure the makemkv is fully updated and it has, Cleaned the disc, disc has no scratches. Restarted the PC and problem not resolved. I did a test on ripping all the other files on the same disc and they all ripped fine only the files that contain the movie it self fails.
Heres the fail report.
Saving 1 titles into directory G:/Video/Incredibles 2
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00817.m2ts' at offset '937881600'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '937881600'
Failed to save title 2 to file G:/Video/Incredibles 2/Incredibles 2_t02.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Re: Bluray ripping error failure
Post by Woodstock » Wed Apr 17, 2024 4:44 pm
Does the offset change when you rip again, or always at the same spot?
Same spot usually means a disk error.
Moving around often means the drive runs out of power trying to spin that fast, which is a different error, which means you need to limit how fast the drive can go, or give it more power. This can happen with USB-powered drives, especially at high offsets. You didn't specify, so I can only raise the possibility.
