PlainSimpleTailor
Hello all!
I've been lurking here for a bit, checking out the various drives, figuring out just how deep I want to get into this entire process, and decided I might as well make it official and create an account. It's only been about two weeks since I started ripping my Blu-Rays, and it's really awesome how MakeMKV is pretty easy to use.
I was just wondering: I looked around a bit but was unable to find any sort of general chat area, does that not exist? It's cool if it doesn't, I just thought it'd be nice to do something other than only ask questions, ask for help, etc. It can sometimes be a little intimidating joining a community like this.
Anyway, that was all, I'll shut up now!
I don’t understand why Alex Coluzzi (alexcoluzzi32@gmail.com) is not mentioned as a seller of drives. I feel like he used to be the only person listed. I’ve bought several drives from Alex and he’s always been available when I had a question.
iam2diezel
believe he goes by Jonghotti and has his own thread on this forum here.Mikeismad wrote: Tue Apr 16, 2024 1:49 am I don’t understand why Alex Coluzzi (alexcoluzzi32@gmail.com) is not mentioned as a seller of drives. I feel like he used to be the only person listed. I’ve bought several drives from Alex and he’s always been available when I had a question.
I'm a bit unsure if my drive is able to be flashed. My model is the "BD-RE WH14NS40" but the instructions says "3. SVC NS50+ LG only on label for NB drives NB50+". I don't understand this and does that mean that my drive can't be flashed?
I have downloaded "The all you need firmware pack" and then followed the "How to Flash videos and commands" instructions. Everything went fine (see output)
But in MakeMKV nothing has changed.
Could someone please tell me what I'm doing wrong - thanks
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d E: rawflash enc -i C:\Users\run\Downloads\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file C:\Users\run\Downloads\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: HL-DT-ST_BD-RE__WH14NS40_1.03_211711211658_M69IC392244
100% Operation finished
Done successfully
OS device name: E:
Product: BD-RE WH14NS40
Revision: 1.03
Serial number: M69IC392244
Firmware date: 2117-11-21 16:58
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.03
No disc inserted-
No encrunnn wrote: Tue Apr 16, 2024 7:55 pm I'm a bit unsure if my drive is able to be flashed. My model is the "BD-RE WH14NS40" but the instructions says "3. SVC NS50+ LG only on label for NB drives NB50+". I don't understand this and does that mean that my drive can't be flashed?
But in MakeMKV nothing has changed.Code: Select all
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d E: rawflash enc -i C:\Users\run\Downloads\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin Reading input file C:\Users\run\Downloads\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin Flashing flags = 0x0 : 0 0 0 0 : ---- ---- ---- ---- Sending image in encrypted format Current Drive ID: HL-DT-ST_BD-RE__WH14NS40_1.03_211711211658_M69IC392244 Ready to write drive flash memory. (auto confirmed) Operation started: Sending flash image to drive 100% Operation finished Operation started: Programming flash 100% Operation finished Done successfully PS C:\Program Files (x86)\MakeMKV>Could someone please tell me what I'm doing wrong - thanksCode: Select all
Drive Information OS device name: E: Manufacturer: HL-DT-ST Product: BD-RE WH14NS40 Revision: 1.03 Serial number: M69IC392244 Firmware date: 2117-11-21 16:58 Bus encryption flags: 17 Highest AACS version: 76 LibreDrive Information Status: Possible (with patched firmware) Drive platform: MT1959 Harware support: Yes Firmware support: No Firmware type: Original (patched version available) Firmware version: 1.03 DVD all regions: Possible (with patched firmware) BD raw data read: Possible (with patched firmware) BD raw metadata read: Possible (with patched firmware) Unrestricted read speed: Possible (with patched firmware) No disc inserted
Thanks a million. May I ask what does it mean to have a non-encrypted firmware? How will affect my use of MakeMKV? Does it mean that I have no reason to flash the drive?No enc
Yeah you don't have encrypted fw.runnn wrote: Wed Apr 17, 2024 7:54 amThanks a million. May I ask what does it mean to have a non-encrypted firmware? How will affect my use of MakeMKV? Does it mean that I have no reason to flash the drive?No enc
You still need to flash it
Does not change anything with makemkv
Hello all
I've had an Asus BC-12D2HT in my system for a while and by looking on this forum it's not clear whether I could flash it to read and rip 4K BD.
Below is the output of MakeMKV, can anybody point me to the right direction? (I believe I am not allowed to add pictures yet?)
Thanks a lot!
OS device name: F:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.00
Serial number: SIK91G2QF134
Firmware date: 2115-12-09 11:47
Bus encryption flags: 1E
Firmware version: 3.00
BD raw metadata read: Partial
No disc inserted-
It can already read UHD discs. Just put one in and start ripping like normal.Tony359 wrote: Fri Apr 19, 2024 3:52 pm Hello all
Thanks a lot!Code: Select all
Drive Information OS device name: F: Manufacturer: ASUS Product: BC-12D2HT Revision: 3.00 Serial number: SIK91G2QF134 Firmware date: 2115-12-09 11:47 Bus encryption flags: 1E LibreDrive Information Status: Enabled Drive platform: MT1959 Firmware type: Original (unpatched) Firmware version: 3.00 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Partial Unrestricted read speed: Yes No disc inserted
What!!! ahah amazing! I had no idea!
Thank you so much!
Thank you so much!
Hi, I have a "verbatim eu" Pioneer BDR-UD03 firmware 1.14 with BDXL icon on it. I try to read a UHD disc and it doesn't work. Is it possible to flash to make it recognize UHD discs and rip them?thanks
Enrique8712
Hello, I've read this guide a couple of times but still feel a little confused because of how it is worded. Could someone help me? I just want to know which one I can buy right now and flash it and have it working? If anyone can help me with this, I would really appreciate the help! I don't want to buy the wrong one and have to keep returning them.
Start here:Enrique8712 wrote: Tue Apr 23, 2024 6:38 pm Hello, I've read this guide a couple of times but still feel a little confused because of how it is worded. Could someone help me? I just want to know which one I can buy right now and flash it and have it working? If anyone can help me with this, I would really appreciate the help! I don't want to buy the wrong one and have to keep returning them.
Drives for sale, Flashing Services, where to buy...
Choose a buyer in your region & contact them via email (usually in the 1st post of the thread) about what you are looking for, current stock, etc..
lifesgucci
ack i found an lg WH14NS40 for $40 in a local store and didn't check the date. it's jan 2015. how borked am i? is it's possible to uhd flash or should i just leave it alone?
Too old... just leave it alone. >Oct 2015 is the target.lifesgucci wrote: Mon Apr 29, 2024 12:47 pm ack i found an lg WH14NS40 for $40 in a local store and didn't check the date. it's jan 2015. how borked am i? is it's possible to uhd flash or should i just leave it alone?
