ASUS BC-12D2HT
Tntdruid
ASUS BC-12D2HT
Post by Tntdruid » Thu Mar 14, 2019 8:38 am
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 1.00
Serial number:
Firmware date: 2113-06-14 12:00
Bus encryption flags: 1E
Drive platform: MT1939
Harware support: Yes
Firmware support: No
Firmware version: 1.00
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
Any plan to add support for that drive?
Re: ASUS BC-12D2HT
Post by Woodstock » Thu Mar 14, 2019 12:54 pm
Kind of wondering why you're asking? Or are you thinking that the program would say this if the author had no intention of following through?
Re: ASUS BC-12D2HT
Post by Billycar11 » Thu Mar 14, 2019 7:06 pm
Just a fwi don't flash that drive it won't enable libredrive and won't make it uhd friendly it will just make it read no disks
Re: ASUS BC-12D2HT
Post by mike admin » Fri Mar 15, 2019 3:24 pm
Now there is one more option available. You can flash 3.01 MK firmware. It won't do magic and make your drive UHD compatible (hardware is not there) but it will make your drive LibreDrive compatible - meaning you will read any BD or DVD disc forever and won't worry about AACS revocations or bus encryption.
thedanshires
Re: ASUS BC-12D2HT
Post by thedanshires » Sun Jun 09, 2019 11:42 am
Hi Mike
I have this drive too, just wondered if there's any kind of timeline when unrestricted read speed will be implemented please? Or is it just a case of it'll be done when it done?
Thanks for this amazing programme.
Rayxcer
Re: ASUS BC-12D2HT
Post by Rayxcer » Thu Jun 13, 2019 1:30 pm
Hello guys,
just fyi, I have the BC-12D2HT and I'm perfectly able to use MakeMKV in combination with this drive to save my UHD Blu Ray disk to my NAS.
So, I'm kinda curious why everyone says that the drive isn't able to - in fact it was even before I flashed that LibreDrive firmware onto it.
Or am I missing something?
morbius
Re: ASUS BC-12D2HT
Post by morbius » Thu Jun 13, 2019 5:38 pm
I believe there are two versions of this drive? Mine is a 2016 model and it reads UHD discs as the factory firmware is friendly, I keep this one in reserve in case my daily driver Asus ever gives up. but think there is an older version with no UHD capability?
st4evr
Re: ASUS BC-12D2HT
Post by st4evr » Thu Jun 13, 2019 9:32 pm
Hello guys,
Forum search function works:
https://www.makemkv.com/forum/viewtopic ... 2HT#p74990
https://www.makemkv.com/forum/search.ph ... =BC-12D2HT
Discussed multiple times already.
starc
Re: ASUS BC-12D2HT
Post by starc » Sun Aug 04, 2019 1:51 pm
can anyone dump the firmware for the old "not patchable yet" version of ASUS BC-12D2HT?
That is, the drive Tntdruid listed the MakeMKV output from:
Product: BC-12D2HT
I was stupid and did not read all forum threads about BC-12D2HT and upgraded it to 3.01,
and now it just opens and closes fine, but will not read anything.
OS device name: E:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.01
Serial number: SIK9OXXXXXXX
Firmware date: 2117-11-15 19:26
Firmware version: 3.01
If someone can dump the original 1.00 fw for it, I will try to downgrade.
Stingray
Re: ASUS BC-12D2HT
Post by Stingray » Mon Apr 15, 2024 8:33 pm
is it possible to crossflash this drive for using with opti drive control to scan for error?
Re: ASUS BC-12D2HT
Post by Coopervid » Mon Apr 15, 2024 9:41 pm
Try BH16NS58 with qpxtools. Optidrive is buggy anyway.
Stingray
Re: ASUS BC-12D2HT
Post by Stingray » Tue Apr 16, 2024 6:38 pm
so this drive with BH16NS58 FW can scan discs? (qpxtools, opti drive..)
good for its price. thanks Coopervid
