Unencrypted Backup from Encrypted Backup
Powerkey
#1 Post by Powerkey » Sat Mar 23, 2024 10:10 pm
I have successfully created an encrypted backup of a damaged UHD disc. The backup contains a working discatt.dat file and I am able to use MakeMKV to extract the videos.
Is there a way to create an unencrypted backup from this encrypted backup that I can turn into an .iso?
Re: Unencrypted Backup from Encrypted Backup
#2 Post by Billycar11 » Sat Mar 23, 2024 11:55 pm
Try using imgburn to make it an iso and mount it as an iso
Powerkey
#3 Post by Powerkey » Sun Mar 24, 2024 1:12 am
I tried that. I made an iso of the encrypted folder and mounted it. But MakeMKV would not see it as a disk. I was able to open the discatt.dat and extract the movie, but there does not appear to be a way to create a backup of it.
Radiocomms237
#4 Post by Radiocomms237 » Sun Mar 24, 2024 1:33 am
It should work, I've done it myself.
As soon as I mount the ISO image (assigning it a virtual drive letter), Windows "AutoPlay" pops up asking me what I want to do with the newly connected drive. I have MakeMKV added to the default programs for optical discs so I just click on that, but if you don't, then just close that popup and open MakaMKV.
You should then be able to select the new drive letter from the "Source" dropdown box as if it were an optical drive, but do NOT "Open" the disc or the backup option will go away (greyed out).
Click on the green/yellow Backup icon, select the destination folder and make sure "Decrypt video files" is now checked, then do another backup.
Powerkey
#5 Post by Powerkey » Sun Mar 24, 2024 3:25 am
I am using macOS. I will give that a try on my old Windows machine.
Thanks for the help.
Rojma
#6 Post by Rojma » Tue Mar 26, 2024 1:10 am
I had a similar need and can confirm that the process works. Just make an ISO image from the encrypted backup folder using ImgBurn, then mount the ISO created by ImgBurn in Windows by double clicking on it. When you mount the ISO, Windows will create a virtual optical drive and assign a drive letter to it. When you start up MakeMKV, MakeMKV will see this virtual optical drive and give you the Backup option in the menu, allowing you to create a decrypted backup.
mustang5o
#7 Post by mustang5o » Tue Apr 16, 2024 12:42 pm
Rojma wrote: Tue Mar 26, 2024 1:10 am I had a similar need and can confirm that the process works. Just make an ISO image from the encrypted backup folder using ImgBurn, then mount the ISO created by ImgBurn in Windows by double clicking on it. When you mount the ISO, Windows will create a virtual optical drive and assign a drive letter to it. When you start up MakeMKV, MakeMKV will see this virtual optical drive and give you the Backup option in the menu, allowing you to create a decrypted backup.
How do you create the encrypted backup folder? Do you just copy all folders (I think I saw 3) from the disc to the computer or do you use MakeMKV and just not check the decrypt option?
Radiocomms237
#8 Post by Radiocomms237 » Tue Apr 16, 2024 3:57 pm
Yes, you can create an encrypted backup using MakeMKV, but why would you?
If you have the disc in the drive, you would simply ignore everything above and make a decrypted backup instead!
The above procedure is only necessary if you have previously made an encrypted backup and want to decrypt it.
mustang5o
#9 Post by mustang5o » Wed Apr 17, 2024 3:12 pm
Radiocomms237 wrote: Tue Apr 16, 2024 3:57 pm Yes, you can create an encrypted backup using MakeMKV, but why would you?
I am having read errors on several discs I'm trying to backup. I read somewhere that making an encrypted backup to the hard drive might help. I thought you could just copy files/folders from the disc to the hard drive then have makemkv look at the files you copied over and make decrypted version. When I look at the disc I'm seeing three folders: AACS, BDMV and CERTIFICATE. I was curious if I need to copy all three in order for this work.
Rojma
#10 Post by Rojma » Wed Apr 17, 2024 6:10 pm
mustang5o wrote: Wed Apr 17, 2024 3:12 pm
It's not quite that easy or straightforward. The following thread has a lot more details:
viewtopic.php?f=10&t=16920
But before trying any of that, start by trying to clean the disc with a microfiber cloth and 91% isopropyl alcohol. This has fixed read errors for me like 95% of the time.
mustang5o
#11 Post by mustang5o » Wed Apr 17, 2024 8:33 pm
Rojma wrote: Wed Apr 17, 2024 6:10 pm It's not quite that easy or straightforward. The following thread has a lot more details:
Thanks I'll investigate that. I have cleaned them quite well though not specifically with 91% isopropyl alcohol. I'll add that to my shopping list.
