Cant flash LG BH16NS40
jackydany
#1 Post by jackydany » Tue Apr 16, 2024 10:08 am
i bought a drive because my older BH16NS40 scratched the disc :(
this one is Firmware 1.03
Manufactured august 2015
i tried the sdftool but every firmware i try, it tells me, the drive is not the correct hardware platform.
are there different hardware revisions for the drive i am not aware of? this one seems to be 1939
in makemkv it shows:
OS-Gerätename: E:
Produzent: HL-DT-ST
Produkt: BD-RE BH16NS40
Revision: 1.03
Serienummer: xxxxxxxx
Firmware-Datum: 2115-05-26 17:14
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 77
Drive platform: MT1939
Firmware version: 1.03
BD raw metadata read: Partial
i didnt realize that there is a revision of ns40 drives that are not patchable.
Any help about this?
Besides the UHD feature, is this drive able to do the same as a flashed / patched one?
Thanks in advance
Re: Cant flash LG BH16NS40
#2 Post by MartyMcNuts » Tue Apr 16, 2024 10:29 am
jackydany wrote: Tue Apr 16, 2024 10:08 am Hi,
OS-Gerätename: E:
Produzent: HL-DT-ST
Revision: 1.03
Thanks in advance
Too old. It's the old hardware version, not the newer one. Don't attempt to flash it! It will never do UHD but can still read BD/DVD/CD the same as any newer drive. Why would you buy a used drive and not a new one?
jackydany
#3 Post by jackydany » Tue Apr 16, 2024 10:38 am
thanks, that what i guessed :(
But i thought all drives from 2015 on are capeable. learned my lesson :D
i bought it used because its much cheaper and does the job.
100+ € new, 35€ shipped used....
#4 Post by MartyMcNuts » Tue Apr 16, 2024 11:50 pm
jackydany wrote: Tue Apr 16, 2024 10:38 am Hi,
You thought wrong!! They started with the MT1959 chipset from around October 2015.
Phoenix0870
#5 Post by Phoenix0870 » Sat Sep 28, 2024 2:03 pm
Hello.
I search sdflasher.exe which is only for mt1939, which has no brake!
It is only intended to release the brake, It should read faster.
My LG BH16NS40 is SVC code NS40.
The firmware V1.03 should release the brake without it being able to rip UHD.
However, it can read and write 100GB BD-RE TDK 2x with UDF format V2.5.
Here the firmware information reading with MakeMKV V1.17.7:
Laufwerksinformation
OS-Gerätename: \Device\CdRom6
Aktuelles Profil: BD-RE
Produzent: HL-DT-ST
Revision: 1.03
Serienummer:
Firmware-Datum: 2114-03-26 11:15
Highest AACS version: 31
Disk-Informationen
Label: 90,2GBTDK UDF2.5
Zeitstempel: 2024-09-28 15:52:52
Datenkapazität: 93.22 Gb
#6 Post by Coopervid » Sat Sep 28, 2024 9:37 pm
Phoenix0870 wrote: Sat Sep 28, 2024 2:03 pm Hello.
Produzent: HL-DT-ST
Revision: 1.03
Serienummer:
Disk-Informationen
You just read what Marty posted. Didn't you? So don't be childish and accept that MT1939 won't work. Tzzzzz.....
Phoenix0870
#7 Post by Phoenix0870 » Sat Sep 28, 2024 11:00 pm
Hello.
I've read it, but if we all know that you can't delete the calibration data, otherwise the drive won't read any media, you could reprogram a sdflasher.exe so that it only flashes the firmware without the calibration data.
It could have been that this has already been reprogrammed.
Ok, I just thought they had reprogrammed something for it in the meantime?!
