Blu-Ray Drives that support UHD out of the box?
whysocomp9090
Post by whysocomp9090 » Mon Apr 15, 2024 1:41 pm
I looked over the thread that discussed drives that could be flashed for UHD, and decided that I do not want to go with that method, as it is too complicated. Instead I would rather just purchase an internal drive that supports UHD out of the box. I would also like it to be a 5.25" drive and not a 9.5 or whatever. Thanks :mrgreen:
Re: Blu-Ray Drives that support UHD out of the box?
Post by Billycar11 » Tue Apr 16, 2024 4:22 am
whysocomp9090 wrote: Mon Apr 15, 2024 1:41 pm I looked over the thread that discussed drives that could be flashed for UHD, and decided that I do not want to go with that method, as it is too complicated. Instead I would rather just purchase an internal drive that supports UHD out of the box. I would also like it to be a 5.25" drive and not a 9.5 or whatever. Thanks :mrgreen:
then your only option is to buy from a drive seller.
i recommend pioneers i have them with old fw.
viewforum.php?f=20
my direct link is below as well as email to order
Post by MartyMcNuts » Tue Apr 16, 2024 5:42 am
All of the 5.25" internal drives require flashing, so your only option there is to buy one already flashed and tested from a seller in your region.
