Blu-Ray Drives that support UHD out of the box?
whysocomp9090
Post by whysocomp9090 »
I looked over the thread that discussed drives that could be flashed for UHD, and decided that I do not want to go with that method, as it is too complicated. Instead I would rather just purchase an internal drive that supports UHD out of the box. I would also like it to be a 5.25" drive and not a 9.5 or whatever. Thanks :mrgreen:
Re: Blu-Ray Drives that support UHD out of the box?
whysocomp9090 wrote: Mon Apr 15, 2024 1:41 pm I looked over the thread that discussed drives that could be flashed for UHD, and decided that I do not want to go with that method, as it is too complicated. Instead I would rather just purchase an internal drive that supports UHD out of the box. I would also like it to be a 5.25" drive and not a 9.5 or whatever. Thanks :mrgreen:
then your only option is to buy from a drive seller.
i recommend pioneers i have them with old fw.
viewforum.php?f=20
my direct link is below as well as email to order
All of the 5.25" internal drives require flashing, so your only option there is to buy one already flashed and tested from a seller in your region.
