Why can't I upload images to the MakeMKV.com forum?
All topics related to functioning of this forum or MakeMKV website
RAHRL
Post by RAHRL »
I have been struggling a few times to upload images to the forum. They seem to upload, but somehow they don't come up as attachment.
Is there something I am doing wrong? Does the site refuse filenames with spaces?
Re: Why can't I upload images to the MakeMKV.com forum?
Just use imgur or similar if you link to photo directly and put in the makemkv img brackets it will embed with the post
RAHRL
Post by RAHRL »
Billycar11 wrote:
Sun Apr 14, 2024 8:38 pm
OK, haven't heard about imgur before, but probably enables me to put an image online and get a url for that image. Good solution, only disadvantage: yet another account.
And it doesn't explain why the MakeMKV doesn't want the images. BTW .txt attachments also do not work.
Thx
I don't know why things are they way they are on this forum, but my speculation is it is a way to prevent the storage needs (and the associated costs) of the server from going to super high levels. Even though a single screen shot isn't all that big, over the years the total amount of storage required for that stuff is not nothing.
RAHRL wrote:
Sun Apr 14, 2024 9:19 pm
Thx
imgur dont need an account
for txt just put in the code blocks </> symbol
As for why you cannot upload... MakeMKV is hosted with limited upload capability. Unfortunately, we hit that limit about a year or so back, and no one seems to want to clean up old uploads. I haven't had time to go and do that. It's been a decade since I had to clean up a forum that way, so my mind doesn't remember if there is a simple way to do it.
Nucleus
Post by Nucleus »
RAHRL wrote:
Sun Apr 14, 2024 8:04 pm
Click "Insert Image" icon in the post dialog which will insert [ img ] [ /img ] (spaced here so the tags show), get url of imgur image and paste between the tags. Eg:
[img]https://i.imgur.com/v7Nyqud.png[/img]
Then preview your post. There was a great right-click imgur uploader for Windows but it stopped working, I've been using this:
https://img.doerig.dev/
The above example - below.
Windows:
Identifying The Correct Title To Rip: Process Monitor Method - GetMPLS Method
Mux/Remux: Set A Subtitle Stream On By Default (Forced)
RAHRL
Post by RAHRL »
Thank you for all the information and examples, it is clear to me now how to do it.
(I tried testing this out, but I don't get it to work at this moment. The image is not coming up in the post. The url itself works in the browser.)
RAHRL wrote:
Mon Apr 15, 2024 10:57 am
Right click the photo on imgur open in new tab and use that URL and it will work as I said the photo directly not the imgur page with the photo
Nucleus
Post by Nucleus »
Do as BillyCarr11 has posted and get the actual image url, are you pasting the url of the Imgur page? Sorry, should have made that more clear in my post - get the actual image url and try again.
Windows:
RAHRL
Post by RAHRL »
Nucleus
Post by Nucleus »
RAHRL wrote:
Mon Apr 15, 2024 12:16 pm
OK, that did the job :D
use:
https://i.imgur.com/kxFYZvm.jpeg
Now if you put that between [ img ] [ /img ] (close the spaces) tags it will display inline in your post.
Windows:
