Office Space Special Edition with Flair
Re: Office Space Special Edition with Flair
Post by mike admin » Tue Aug 16, 2011 4:28 pm
It's not a BD+, it's a fox studio and bug in MakeMKV. Fix should be in a day or two. http://www.makemkv.com/forum2/viewtopic.php?f=1&t=3955
Jimmers
Post by Jimmers » Thu Apr 11, 2024 12:00 pm
I know that this is an old, stale thread but I recently tried ripping a copy of this blu-ray and have run into the same problem. Everything is fine until "Office Space_t01.mkv" reaches 2978.8M and then hangs. It will keep adding hours to the Remaining side of the Elapsed counter until it starts throwing errors.
AACS directory not present, assuming unencrypted disc
File 00011.mpls was added as title #0
File 00012.mpls was added as title #1
Title #00032.mpls has length of 21 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00040.mpls was added as title #2
Title 00001.mpls is equal to title 00040.mpls and was skipped
Title #00025.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00026.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00021.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00022.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00037.mpls has length of 50 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title 00010.mpls is equal to title 00011.mpls and was skipped
Title #00030.mpls has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00024.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00003.mpls was added as title #3
Title 00007.mpls is equal to title 00011.mpls and was skipped
Title #00020.mpls has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00023.mpls has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title 00003.m2ts is equal to title 00011.mpls and was skipped
Title #00004.m2ts has length of 1 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00007.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00009.m2ts has length of 1 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00010.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00017.m2ts has length of 30 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00014.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00018.m2ts has length of 27 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00002.m2ts has length of 55 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title 00005.m2ts is equal to title 00012.mpls and was skipped
File 00006.m2ts was added as title #4
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00011.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00016.m2ts has length of 20 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00015.m2ts has length of 15 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title 00011.mpls is equal to title 00003.mpls and was skipped
Saving 1 titles into directory D:/Video/Office Space
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 3172196352, attempting to work around
Error 'Internal error - Operation was cancelled (140)' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '3172202496'
Failed to save title 1 to file D:/Video/Office Space/Office Space_t01.mkv
0 titles saved, 1 failed
I've examined the disk and found no visible damage. I can play it on a regular blu-ray player. I see that MakeMKV has skipped another title that it decided was the wrong one, but I don't know how to select it to see if might rip.
I have also tried it on a different drive.
Do I just have a bad disk?
Post by dcoke22 » Fri Apr 12, 2024 2:17 am
Are you trying to rip from a disc?
"AACS directory not present, assuming unencrypted disc" is an unusual thing to see in a log for a blu-ray.
^ messages like that usually mean the optical drive is unable to correctly read a spot on the optical disc. The standard advice is to gently clean the disc and try again.
