sultanmehmet
Post by sultanmehmet »
RESET_9999 wrote:
Sat Apr 13, 2024 11:53 am
Anime0t4ku wrote:
Fri Apr 12, 2024 5:10 pm
@Reset9999, got any suggestions to get FEL MKV's to work propperly with Kodi?
I don't know about Kodi but it plays fines in PLEX on my end(except for the slight BL_EL OOS)
We just received the Nokia 8010 which has the amlogic S905X4-K chip (with the dolby vision license) but can't get DV FEL to work in CoreElec V21.0. There is very little written about this little box as the bulk of the information is about the AM6B and plus models. Technically it should be able to play it in CoreElec seeing as how the Chromecast 4k has the lower-end/older S905X3 chip and DV FEL works on there.
DV is triggered but the test video (this device can decode FEL) stays red, so I think it plays it in MEL-compatible mode (profile 8.1 or similair). FEL also doesn't work in the Android TV os that it comes with out of the box. We tried it in Plex the same way as we did with the CCTV 4K and it didn't work. Also enabled the ''force profile 7'' option you mentioned for the CCTV, it didn't work.
The reason we went for the Nokia 8010 was because it cost us 99 euros at Amazon. The Ugoos is either not available anywhere or marked up so I wanted to leave that option for later.
UPDATE: After seeing the availability and pricing of the AM6B+ I decided that the newer AM8 is a better option. I can get that for about the same price as the AM6B+, sometimes even cheaper! It has the newer and updated S928X-J chip and should also work.
texwatson
Post by texwatson »
sultanmehmet wrote:
Sat Apr 13, 2024 12:22 pm
"Dolby Vision will be supported on Amlogic-ne and Amlogic-ng with Kodi Omega on certain Amlogic devices like Homatics/Dune R 4K Plus, RockTek G2 or Nokia 8010. Other devices on Amlogic-ng like Ugoos AM6+ or Minix NEO U22-XJ (Max) equiped with S922X-J will support Dolby Vision with profile 7 FEL as well."
What's the point of buying an AM8? Looks pretty much worthless to me.
sultanmehmet
texwatson wrote:
Sat Apr 13, 2024 4:27 pm
The AM8 has the successor chip to the AM6B+ that everybody is boasting about. And like I said in my post, since the AM6B+ is sold almost everywhere in my country and beyond (Europe) the AM8 is actually cheaper with a more direct availability. So I don't necassarily want it because it's 'better' but because it's more easily available and actually cheaper to get. I know Portisch, the CoreElec developer has one and is working on it. I have a Sony X700 which works but has too many cons while playing FEL movies so I would like something with more ease of use. Am in no way in a hurry to get a streamer that works.
susanstone2022
Post by susanstone2022 »
sultanmehmet wrote:
Sat Apr 13, 2024 5:28 pm
you don't get the point. FEL support needs both hardware and software. At this time, software does not support FEL on AM8. It does not matter if it is newer or better or cheaper.
sultanmehmet
susanstone2022 wrote:
Sat Apr 13, 2024 5:37 pm
I got that. I know it's being worked on and I have a sony x700 to keep me satisfied for FEL playback while the software part of the AM8 gets optimized. I'll wait if need be, the development at CoreElec seems to have made great progress in the last few months so I'm pretty sure we'll get something working sooner rather than later. And if not then I can just act accordingly then. Am in no way in a hurry to get a streamer that works.
susanstone2022
sultanmehmet wrote:
Sat Apr 13, 2024 5:41 pm
I got that. But it will take some time for me to get it here anyway and I have a sony x700 to keep me satisfied while the software part of the AM8 gets optimized. I'll wait if need be, the development at CoreElec seems to have made great progress in the last few months so I'm pretty sure we'll get something working sooner rather than later. And if not then I can just act accordingly then. Am in no way in a hurry to get a streamer that works.
do you know if Amlogic S928X-J has two decoders which is required for FEL decoding?
sultanmehmet
Sat Apr 13, 2024 5:45 pm
According to Portisch's (a developer for CoreElec) response to a statement about multiple decoders and the S928X chip, it does.
Statement:
''You cannot support FEL via a firmware update because FEL is actually 2 videos overlaid on top of each, so it requires 2 H.265 decoders which this chip does not have. The S905X5 apparently has 2 decoders so that might be able to decode FEL depending.''
Portisch:
''This is not true, there up to 9 decoder in hardware supported since years. I think since g12a.
It’s just not usable as Kodi is only able to handle one decoder and not two simultaneously like for PiP.
We use for FEL already two decoders but the problem is when one frame decode fail all get stuck..''
cpm00
Post by cpm00 »
I guess maybe talking at cross purpose, the chips have multiple decoders - but they are for different types of decoding h.264, AV1, VP9 etc.
DoVi UHD BluRay needs 2x h.265 (1x h.265 2160p @ 60fps and 1x h.265 1080p @ 60 fps).
I can not find anywhere which explicitly indicates the S928X can do that combo - though it is possible it can.
Note: Kodi is just passing down the ST-DL video stream to the AMLogic drivers/codebase to do the actual decoding and composition of the two h.265 (HEVC) streams (BL and FEL) for DoVi, recently there was an issue in CoreELEC 21 with seeking - landing in between I-Frames and the decoding becoming stuck - that one was solved.
Presuming the chip is good the next hurdle will be getting all the open source linux drivers required for CoreELEC - from what I see they have not been released - some important elements are missing, and all are only available for Android - for the versions the S928X needs.
Would need pressure on AMLogic or more likely the 3rd party box makers to put pressure on AMLogic to get the drivers released for linux.
Speculation: Higher bandwidth streaming is arriving - and I would dare say this will ultimately surpass DoVi UHD BluRay if the demand is there i.e. will bump to 12bit when sensibly priced consumer displays become available to close any remaining gap.
Big-rome
Post by Big-rome »
No work is being done on the AM8. S905X4-K doesn't support FEL. Also the AM6B+ is available on aliexpress $152 USD plus taxes and free shipping.
sultanmehmet
Big-rome wrote:
Sun Apr 14, 2024 5:08 pm
I know they're waiting on drivers and other things so it's in the queue. We tested the Nokia boxes extensively but sent them back to Amazon because one wouldn't start up anymore, so in the end it didn't really matter either way.
The AM6B+'s on Aliexpress for $152 I've found myself too but after you login they all become $184 or more (I have a CC limit of $175). Probably some deal for first time buyers that gets removed after you log in. If yours is a different one that stays at $152 I'll gladly take that deal.
UDPATE: Bit the bullet and bought an AM6B+ from Aliexpress for $190 including shipping by using afterpay :lol: . It was the cheapest I could get it from Aliexpress. Should arrive in about 2 weeks.
Big-rome
Post by Big-rome »
sultanmehmet wrote:
Sun Apr 14, 2024 7:08 pm
The seller PLAY TV has the cheapest price I found. $166.28 with tax and free shipping. Im waiting on my second AM6B+ now.
sultanmehmet
Ordering from Play TV would have cost me $192 all combined. I ordered it from Diffingle Store where it was a little bit cheaper. A second one, nice.
How is fast forwarding FEL movies? Does it crash in CoreElec while attempting to go to the next chapter or fast forwarding?
Big-rome
Post by Big-rome »
sultanmehmet wrote:
Mon Apr 15, 2024 1:22 am
Next chapter and fast forwarding works great. Best player to have right now for local playback.
DylanValenti
Post by DylanValenti »
Any idea what's happening here?
Choice? [1,2,3,4,5,6,7,8,9]?9
-- This script export a timecode EDL file for Resolve from DV or HDR10plus source
-- You must have the Dolby Metafier in the tools folder
-- Input can be XML/RPU/MKV/M2TS/TS/MP4/HEVC/JSON
-- If input is not a video, the script assume it's 23.976 unless you add in the filename: '24FPS' '25FPS' '60FPS'
Drag and drop a DoVi file and press enter...Z:\Aliens\Extras\RPU.bin
04/15/2024/02:28:40.283000000 metafier: ERROR Incorrect filename range syntax
Traceback (most recent call last):
  File "Z:\[DoVi]\tools\EDL_maker.py", line 56, in <module>
    convert_frames_to_smpte(args.input, args.output, args.fps)
  File "Z:\[DoVi]\tools\EDL_maker.py", line 31, in convert_frames_to_smpte
    with open(input_file, 'r') as infile, open(output_file, 'w') as outfile:
FileNotFoundError: [Errno 2] No such file or directory: 'Z:\\[DoVi]\\temp.folder78\\shotlist.duration.txt'
The script has been completed. Do you want to quit or go back to main menu (q or m default=q)?
DylanValenti wrote:
Mon Apr 15, 2024 9:35 am
Not sure how many times I have to say it but:
''no space nor special characters in the script folder name and path!!! ''
dolby professional tool does not accept []
Z:\[DoVi]
