Pioneer BDR 209 "No Disc inserted"
Milchr3is
Post by Milchr3is »
Hello there,
I have the following drive:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.51
Serial number: RKDL007161WL
Firmware date: 2018-05-08
Bus encryption flags: 13
Highest AACS version: 39
Drive platform: RS8601
Firmware version: 1.51/ID60
I have the problem that it only reads like 20% of my BR disks. Maybe even less. When I put the discs in it shortly states that it is loading the disc but then changes its mind to "No Disc inserted". I tried the following already: set the "read retry" to a highger level, only turn on the drive when makemkv is running, I made sure the discs are fine with playing them with my normal blu ray player and tried a different software. Would flashing the player help maybe or is it a hardware problem?
Thank you very much in advance!
Re: Pioneer BDR 209 "No Disc inserted"
Generally you don't flash Pioneer drives. Pioneer firmware update February 2023
It is possible the optics on your drive are a bit dirty. I'm not an expert on cleaning drive optics, but I do know it can be done.
Milchr3is
Post by Milchr3is »
Thank you for getting back to me! I will try it out asap and report back :)
