Post by RESET_9999 » Thu Apr 11, 2024 11:05 pm
Also tried to set HW overlay to off (which I have to turn on disable HW overlay ironically) but it didn't help the Kodi stuttering.
On my end, GTV PLEX is unwatchable when ''HW overlay'' is not disabled. Micro stuttering every 30 seconds or so.
Anime0t4ku
Post by Anime0t4ku » Thu Apr 11, 2024 11:16 pm
sultanmehmet wrote: Thu Apr 11, 2024 10:24 pm
RESET_9999 wrote: Thu Apr 11, 2024 10:11 pm Go into the Plex settings and make sure that ''force profile 7'' is enabled.
The Chromecast seems to have some EL/BL sync issues though. Check out this test file, there's is an encoding bug/artifacts in the HDR10 BL that FEL can fix but it doesn't work on the Chromecast. I also tried to let play Power Rangers till the end the indeed the ending credits text was white but looked slightly out of sync compared to my x800m2 and Ugoos.
comparison BL/EL: https://slow.pics/c/6AdFnUR2
TEST file: https://drive.google.com/file/d/1ir6r2D ... drive_link
EDIT: about the stuttering, try switching off the HW overlay in the developer settings
Bro, mad thanks man! It now works! I have NO IDEA why that settings magically turned itself off in Plex as I'm 100% sure I didn't turn it off myself.
Also tried to set HW overlay to off (which I have to turn on disable HW overlay ironically) but it didn't help the Kodi stuttering. But to be fair, I don't care about that anymore since the only reason I installed Kodinerds in the first place was because it wasn't working in Plex anymore. Now that it works in Plex I don't need to have it be working in Kodi too but thanks for the tip anyway!
I'm the friend sultanmehmet is talking about. Plex seems to "work" now except for the continious buffering I get with FEL DV movies (MEL seems to play fine, even with similiar file sizes and bitrates) however, I'm more interested in getting FEL to work with Kodi, disabling the hardware overlay doesn't seem to fix the issue for me. Any other suggestions ? Thanks in advance
kazuma
Post by kazuma » Fri Apr 12, 2024 4:19 am
Can DL-DV added with a software update in the future on the ugoos (coreelec)? Or is the hardware of ugoos limited to support this?
Post by RESET_9999 » Fri Apr 12, 2024 11:01 am
it already supports dual-layer DV...
kazuma wrote: Fri Apr 12, 2024 4:19 am Can DL-DV added with a software update in the future on the ugoos (coreelec)? Or is the hardware of ugoos limited to support this?
foxbat
Post by foxbat » Fri Apr 12, 2024 11:03 am
I believe the issue there is that Kodi simply can't handle multiple track playback. This is also why it can't play DV from a UHD ISO - it will only play the first track and fallback to HDR10. Doesn't sound like there's a lot the CoreELEC devs can do about that until support for playing multiple tracks is added to Kodi upstream.
kazuma
Post by kazuma » Fri Apr 12, 2024 11:38 am
RESET_9999 wrote: Fri Apr 12, 2024 11:01 am it already supports dual-layer DV...
Sorry, i mean DT-DV.
Post by RESET_9999 » Fri Apr 12, 2024 12:04 pm
it's a kodi limitation and there's no point using DT-DL mp4/ts/m2ts on this device. MKV is a much better container.
sultanmehmet
Post by sultanmehmet » Fri Apr 12, 2024 4:27 pm
I now have a couple of FEL P7 DT DV movies that I want to convert to FEL P7 ST in order to play them in Plex. I use macOS myself, is there a handy tool to convert/mux DT to ST? I heard RESET saying that it's now possible to do in MKVtoolnix, but I don't really know how to use that tool.
I also downloaded dovi_tool 2.2.1 for macOS but it opened a command line where I didn't quite understand what to do.
I can use windows if need be.
Post by RESET_9999 » Fri Apr 12, 2024 4:43 pm
sultanmehmet wrote: Fri Apr 12, 2024 4:27 pm I now have a couple of FEL P7 DT DV movies that I want to convert to FEL P7 ST in order to play them in Plex. I use macOS myself, is there a handy tool to convert/mux DT to ST? I heard RESET saying that it's now possible to do in MKVtoolnix, but I don't really know how to use that tool.
It only works with DT-DL TS/M2TS rip. If it's an MP4, for some reason mkvtoolnix keeps it DT-DL.
So for m2ts/ts file, just remux it in mkvtoolnix.
For MP4, I guess you have to remux it to TS and then to MKV.
both tsmuxer and mkvtoolnix are available on mac
https://github.com/justdan96/tsMuxer/releases
https://mkvtoolnix.download/downloads.html
Anime0t4ku
Post by Anime0t4ku » Fri Apr 12, 2024 5:10 pm
Anime0t4ku wrote: Thu Apr 11, 2024 11:16 pm
@Reset9999, got any suggestions to get FEL MKV's to work propperly with Kodi?
kazuma
Post by kazuma » Sat Apr 13, 2024 10:04 am
Is the ugoos powerful enough to run a 5TB external usb hdd via usb-ports? Or do you need a usb-hub with power adapter?
Post by RESET_9999 » Sat Apr 13, 2024 11:53 am
Anime0t4ku wrote: Fri Apr 12, 2024 5:10 pm @Reset9999, got any suggestions to get FEL MKV's to work propperly with Kodi?
I don't know about Kodi but it plays fines in PLEX on my end(except for the slight BL_EL OOS)
sultanmehmet
Post by sultanmehmet » Sat Apr 13, 2024 12:22 pm
RESET_9999 wrote: Sat Apr 13, 2024 11:53 am
We just received the Nokia 8010 which has the amlogic S905X4-K chip (with the dolby vision license) but can't get DV FEL to work in CoreElec V21.0. There is very little written about this little box as the bulk of the information is about the AM6B and plus models. Technically it should be able to play it in CoreElec seeing as how the Chromecast 4k has the lower-end/older S905X3 chip and DV FEL works on there.
DV is triggered but the test video (this device can decode FEL) stays red, so I think it plays it in MEL-compatible mode (profile 8.1 or similair). FEL also doesn't work in the Android TV os that it comes with out of the box. We tried it in Plex the same way as we did with the CCTV 4K and it didn't work. Also enabled the ''force profile 7'' option you mentioned for the CCTV, it didn't work.
The reason we went for the Nokia 8010 was because it cost us 99 euros at Amazon. The Ugoos is either not available anywhere or marked up so I wanted to leave that option for later.
UPDATE: After seeing the availability and pricing of the AM6B+ I decided that the newer AM8 is a better option. I can get that for about the same price as the AM6B+, sometimes even cheaper! It has the newer and updated S928X-J chip and should also work.
texwatson
Post by texwatson » Sat Apr 13, 2024 4:27 pm
sultanmehmet wrote: Sat Apr 13, 2024 12:22 pm
"Dolby Vision will be supported on Amlogic-ne and Amlogic-ng with Kodi Omega on certain Amlogic devices like Homatics/Dune R 4K Plus, RockTek G2 or Nokia 8010. Other devices on Amlogic-ng like Ugoos AM6+ or Minix NEO U22-XJ (Max) equiped with S922X-J will support Dolby Vision with profile 7 FEL as well."
What's the point of buying an AM8? Looks pretty much worthless to me.
sultanmehmet
Post by sultanmehmet » Sat Apr 13, 2024 5:28 pm
texwatson wrote: Sat Apr 13, 2024 4:27 pm
The AM8 has the successor chip to the AM6B+ that everybody is boasting about. And like I said in my post, since the AM6B+ is sold almost everywhere in my country and beyond (Europe) the AM8 is actually cheaper with a more direct availability. So I don't necassarily want it because it's 'better' but because it's more easily available and actually cheaper to get. I know Portisch, the CoreElec developer has one and is working on it. I have a Sony X700 which works but has too many cons while playing FEL movies so I would like something with more ease of use. Am in no way in a hurry to get a streamer that works.
