BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
Post by Coopervid » Mon Apr 01, 2024 8:22 am
sense wrote: Mon Mar 25, 2024 9:26 pm Hello Coopervid,
could you please send me the instructions to downgrade the XS07U to a libredrive firmware ?
If your firmware is younger than Dec. 2022 you are out of luck and should return it.
Post by Coopervid » Mon Apr 01, 2024 8:25 am
Edward1017 wrote: Mon Apr 01, 2024 7:17 am Hello Coopervid,
I also picked up one of these drives recently. Mine is on firmware 1.00.
Can you also PM me with the instructions?
Read your PM.
brandonuhd
Post by brandonuhd » Sat Apr 06, 2024 3:46 am
Looking to flash my BDR-XD07S for UHD. Coopervid, can you PM me?
TIA!
Chillkill
Post by Chillkill » Mon Apr 08, 2024 4:17 pm
Hi Coopervid,
Was about to pick up one of these drives. If it has firmware version 1.03 would I be able to roll the firmware back to a version that works with mkv? If so can you send me instructions on how to flash it? Thank you!
Post by Coopervid » Tue Apr 09, 2024 9:26 am
Chillkill wrote: Mon Apr 08, 2024 4:17 pm Hi Coopervid,
No, firmwares younger than Dec. 2022 can't be flashed. If so, return the drive.
Post by Coopervid » Tue Apr 09, 2024 9:27 am
brandonuhd wrote: Sat Apr 06, 2024 3:46 am Hi,
TIA!
What firmware and date has the drive?
brandonuhd
Post by brandonuhd » Tue Apr 09, 2024 2:32 pm
Coopervid wrote: Tue Apr 09, 2024 9:27 am
TIA!
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.05
Serial number: ------
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 72
Drive platform: Pioneer RS8D30
Firmware version: GENE
Post by Coopervid » Tue Apr 09, 2024 4:02 pm
brandonuhd wrote: Tue Apr 09, 2024 2:32 pm
TIA!
Revision: 1.05
You are out of luck. Firmware is newer than Dec. 2022.
benh1
Post by benh1 » Thu Apr 11, 2024 12:44 pm
Hi Coopervid
I have the top-loading version of this drive. Will the UHD firmware work with it? If so, any chance I could have a copy?
Many thanks
Revision: 1.02
Serial number:
Firmware date: 2019-09-05
Drive platform: RS8D30
Firmware version: 1.02
Post by Coopervid » Fri Apr 12, 2024 9:15 am
benh1 wrote: Thu Apr 11, 2024 12:44 pm Hi Coopervid
Many thanks
Revision: 1.02
Serial number:
Read your PM.
NotTheOne
Post by NotTheOne » Sun Apr 14, 2024 7:36 pm
Hi Coopervid, could you PM the info on this too?
Post by Coopervid » Mon Apr 15, 2024 10:57 am
NotTheOne wrote: Sun Apr 14, 2024 7:36 pm Hi Coopervid, could you PM the info on this too?
Post your Makemkv info.
benh1
Post by benh1 » Thu Apr 25, 2024 12:14 pm
Read your PM.
Thank you. I have yet to flash the drive, as I've been ripping my HD discs so far. After flashing, will the drive still be a libredrive? If it won't, is there a way to go back to the factory firmware?
Post by Coopervid » Thu Apr 25, 2024 2:59 pm
benh1 wrote: Thu Apr 25, 2024 12:14 pm
Read your PM.
It will. And yes, that is also possible.
stoggi
Post by stoggi » Sat Apr 27, 2024 12:37 pm
Hi Coopervid,
I also got a Pioneer BDR-XS07 with Firmware 1.01.
Can you please send me a PM with the Informations to upgrade?
Thank you so much :-)
