LibreDrive for Pioneer drives
#931 Post by Billycar11 » Thu Mar 28, 2024 7:57 am
Evil Teddy wrote: Thu Mar 28, 2024 6:53 am
Billycar11 wrote: Wed Mar 27, 2024 10:49 pm Sorry man that drive is to new.
If you can I recommend you return it if you want UHD and a pioneer best to get from a seller in your region
Asmcom seller in this forum said that this drive is compatible with makemkv. Link: viewtopic.php?p=73484#p73484
yeah but you didnt buy his with old fw
Evil Teddy
#932 Post by Evil Teddy » Thu Mar 28, 2024 8:28 am
MartyMcNuts wrote: Thu Mar 28, 2024 7:03 am
The drive is compatible only when it has older firmware (prior to Dec 2022).
Ah okay. I have version 1.03 and I need 1.02 which is supported. I try do downgrade but I think I have to return the drive and get an older one. That's too bad. I like this drive very much :D
#933 Post by Billycar11 » Thu Mar 28, 2024 8:36 am
Evil Teddy wrote: Thu Mar 28, 2024 8:28 am
no one can downgrade the usb ones has to come from the factory with old fw
Evil Teddy
#934 Post by Evil Teddy » Thu Mar 28, 2024 9:33 am
Billycar11 wrote: Thu Mar 28, 2024 8:36 am
Okay, that's sad. Then I will return the drive and try get the same with older fw or a similar one.
jcfrosty
#935 Post by jcfrosty » Thu Apr 11, 2024 1:59 am
Possible, not yet enabled. What should I do?
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-S13U
Revision: 1.04
Serial number: CDDL300398UC
Firmware date: 2022-12-12
Highest AACS version: 75
Firmware version: ID43
#936 Post by Billycar11 » Thu Apr 11, 2024 2:08 am
jcfrosty wrote: Thu Apr 11, 2024 1:59 am Possible, not yet enabled. What should I do?
Revision: 1.04
for now return it and buy one with old firmware from a seller like me or one in your region
jcfrosty
#937 Post by jcfrosty » Thu Apr 11, 2024 2:38 am
Billycar11 wrote: Thu Apr 11, 2024 2:08 am
Revision: 1.04
No can do, I bought this thing over a year ago with the expectation it would eventually be supported. I already purchased a different drive from you in the meantime while I was waiting for this drive to get some support. Its not like I'm stuck, just curious what to do considering the status is "possible, not yet enabled".
#938 Post by MartyMcNuts » Thu Apr 11, 2024 3:15 am
jcfrosty wrote: Thu Apr 11, 2024 2:38 am
Revision: 1.04
You will just have to wait and see. It could be in a year or two or never. Who knows....
TKBiggolo
#939 Post by TKBiggolo » Sun Apr 28, 2024 12:01 pm
Dear all,
I am new to this forum and I hope I am posting in the correct thread. I have recently started ripping my DVD and Blu Rays which is working just fine with my recently purchased Pioneer Drive. Although I do not yet own 4k Blu Rays I am interested to know whether my drive qualifies for flashing/UHD ripping. Below you can see me drive info. Thanks a lot in advance for your help!
Product: BD-RW BDR-213M
Revision: 1.04
Serial number: CHDL001316WL
Highest AACS version: 68
Drive platform: Pioneer RS9200
Firmware version: ID56
#940 Post by Billycar11 » Sun Apr 28, 2024 12:21 pm
TKBiggolo wrote: Sun Apr 28, 2024 12:01 pm Dear all,
Revision: 1.04
Sorry no that drive won't ever do UHD for now
If you want a UHD one return that while you still can and get a pioneer with old fw from a seller in your region I'm in USA and have 30+ drive with old fw in stock or on the way.
BlackHawk 101
#941 Post by BlackHawk 101 » Mon Apr 29, 2024 10:31 pm
I just purchased a BDR-XD08UMB-S
MakeMKV does see it but gives me a this message:
The drive is Drive Information
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number:
Firmware date: 2022-12-27
Highest AACS version: 72
Drive platform: Pioneer RS9331
Firmware version: ID05
Disc Information
Label: KNIVES_OUT
Timestamp: 2020-01-04 16:37:00
Protection: AACS2.0/C v72
Data capacity: 93.22 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Any hope for this drive?
#942 Post by Billycar11 » Tue Apr 30, 2024 1:52 am
BlackHawk 101 wrote: Mon Apr 29, 2024 10:31 pm I just purchased a BDR-XD08UMB-S
Revision: 1.02
Serial number:
Disc Information
Label: KNIVES_OUT
Number of layers: 3
sorry man that wont do UHD for now when or if it will is unknow
if you want UHD from a pioneer see the seller page im the USA seller for pioneers with old FW
BlackHawk 101
#943 Post by BlackHawk 101 » Tue Apr 30, 2024 4:25 pm
Thank You. Trying to educate myself on this process (tinkering) as I am running a PLEX server. for my personal home use Trying to get all my purchased media on my server as 1. backup and 2. convenience.
TKBiggolo
#944 Post by TKBiggolo » Wed May 01, 2024 8:10 am
Billycar11 wrote: Sun Apr 28, 2024 12:21 pm
Revision: 1.04
Hi Billy,
thanks for the quick reply. As for the moment I am fine with just ripping regular blu ray discs I will keep the drive for now. However, in the future I might also wanna turn to UHD blu rays and therefore would like to understand a few things better:
Technically the drive is able to read BD-XL discs, meaning it can technically also read UHD blu rays. Correct?
The reason it cannot read 4K UHD discs is because the installed firmware prevents it from doing it. Correct?
Currently this drive can only be flashed when the installed firmware is dated before 2022-12-12. Correct?
You say the drive won't do UHD for now. That implies in the future it might become possible, given that somebody figures out how to flash this version of the firmware without bricking the drive?
Thanks a lot for helping me understand this better!
Icebraker
#945 Post by Icebraker » Wed May 08, 2024 12:41 pm
Hi all,
I just got a new pioneer BDR-UD03 1.14, ripped a blu-ray straight with makemkv with no problems.
But when I put a UHD Disk into the drive it spits it back out after like 10-15 seconds.
Anybody able to help me or point me in the right direction?
Any help would be greatly appreciated.
Laufwerksinformation
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: AFDL414057WL
Firmware-Datum: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
