Failure to rip BTTF Part 3 (UHD)
Davidpe76
#1 Post by Davidpe76 » Fri Jun 02, 2023 2:28 pm
Managed to rip Back the to Future 1 & 2, but 3 is giving the "failed to open disc" error.
Damn was hoping to watch all 3 in a row, error data was saved but I could not attach due to
'quota error"
I am using licensed version.
polskasubie
Re: Failure to rip BTTF Part 3 (UHD)
#2 Post by polskasubie » Fri Jun 02, 2023 6:14 pm
you need to submit the dump file to svq@makemkv.com
viewtopic.php?f=12&t=24711
Exrill
#3 Post by Exrill » Sat Jun 03, 2023 10:32 am
'quota error"
Mhhhh.. Interesting, I take it that you are ripping from the Boxset "Back to the Future the Ultimate Trilogy" you see I kind of have this problem BUT with with Back the to Future 1 the disc makes my Asus drive spin like crazy.
Davidpe76
#4 Post by Davidpe76 » Sat Jun 03, 2023 12:46 pm
Thank You
scorp508
#5 Post by scorp508 » Mon Jun 12, 2023 1:18 pm
I also had issues with this box set over the weekend. The UHD discs for parts 1 and 2 were the two I couldn't rip. They'd open, but various errors until failure with my Asus drive. Disc 3 ripped fine. The drive sounded like it was ready to lift off to space.
Back to the Future: Blu-Ray fine, 4K fail.
Back to the Future Part II: Blu-Ray fine, 4K fail.
back to the Future Part III: Blu-Ray fine, 4K fine.
BD-RE ASUS BW-16D1HT flashed to 3.10.
binaryflow
#6 Post by binaryflow » Mon Jun 12, 2023 2:49 pm
Anyone can provide more insight about this? I was going to buy it, as I'm a BTTF die hard fanboy (I confess...)
AMCross
#7 Post by AMCross » Sat Aug 26, 2023 9:25 am
got the same BUT disc 1 and 3 read ok
disc 2 reads one minute but fails the next and seems to be seeking back and forth
scorp508
#8 Post by scorp508 » Mon Nov 13, 2023 1:36 pm
For what it's worth, I've made no changes other than upgrading MakeMKV to 1.17.5 from its previous release and I was finally able to rip Back to the Future 1 & 2 UHD discs, which previously failed.
I can't say for sure if it was the version upgrade, the latest HK download, or something else for sure. I recently retried a different UHD disc (Ralph Breaks the Internet) which always failed in the past and it worked, so then I retried a couple other previously failed UHDs which also worked. I popped in my BTTF 1 & 2 UHD discs and on the first try both ripped successfully.
ben_uk
#9 Post by ben_uk » Wed Nov 15, 2023 7:27 am
I haven’t yet come across a single disc that I’ve been unable to rip. Granted, some discs have been very difficult and needed 40-50 attempts at opening but eventually they have all opened and decrypted.
Slimjinxs
#10 Post by Slimjinxs » Mon Jan 15, 2024 2:31 pm
I'm struggling to back up all three movies on the UK version Ultimate trilogy boxset. Any ideas? :x :x :x :x
Thanks in advanced.
LordVader2K
#11 Post by LordVader2K » Wed Apr 10, 2024 7:04 pm
I tried to rip the backt to the future part III disc, this is the error I get.
MakeMKV v1.17.6 win(x64-release) started
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLNNAHF2729' at offset '33364312064'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLNNAHF2729' at offset '33364375552'
udf: node fe/efe failed!
I was able to rip part I and II.
I cleaned the part III disc, it showed some kind of marks, used distilled water and non lint cloth.
#12 Post by Coopervid » Wed Apr 10, 2024 8:03 pm
Send the discs back and ask for exchange. Especially the set in Asia is bad.
