DylanValenti
Post by DylanValenti »
RESET_9999 wrote:
Mon Apr 08, 2024 11:20 am
workflow (1-1) but you have to add ''JUSTINJECT'' in the BL filename to keep it P7
I see thank you!
Yoshitaka
Post by Yoshitaka »
Which DV profiles in MP4 container work on QM850G?
Does MKV work?
Donpoku
Post by Donpoku »
RESET_9999 wrote:
Sun Apr 07, 2024 8:54 pm
Just make yourself one with workflow 4-3
Hi RESET, your fel test looks different on my lg c6, what is your DV picture mode settings i.e oled light, contrast etc? Thanks, your can pm if don't want it public. Mine is oled light: 100; contrast: 95; brightness:50 ;sharpness: 10; colour: 85 and tint:0.
Different? Dont compare the picture from a youtube video with what you see in real life. The point of the FEL test file is that you can see the text that tells you your devices support FEL and the brightness change to L1 L2 L8
My C2 is calibrated in Cinema mode OLED 100.
DylanValenti
For cm analyze I noticed that I got a message
“WARNING plugin does not contain dlb_plugin_file_io_init_v1”
However it seems to be proceeding despite that warning. Should I be worried or am I fine?
it says that with the latest CM version. It doesn't affect the outcome.
Donpoku
Post by Donpoku »
RESET_9999 wrote:
Tue Apr 09, 2024 10:57 am
Thanks again. On my lg c6 only l1/l2 has brightness change not l8, btw which file specific for test on lg c6, I use one of the Chroma cmv4.0 but my tv is only. CMv2.9
Yes, L3-L8 won't have any effect on your CMV2.9 TV. With the FEL test file, it should display the ''this device supports FEL'', react to L1/L2 and L5 at the end of the pattern.
For the chroma weight test, you should test only the cmv2.9 version but some of the CW test files(eagle beak) I did might have both cmv2.9/4.0 blocs within the same file.
texwatson
Post by texwatson »
Hi guys, any FEL P7 sample available to donwload? Thanks.
sw5163
Post by sw5163 »
texwatson wrote:
Wed Apr 10, 2024 12:26 am
Under @RESET_9999's signature DoVi Playback Devices, select DoVi TEST FILES/PATTERNS, and FEL TEST is there. It's a little hard to find.
texwatson
Post by texwatson »
Found them! Thank you and also @RESET_9999 for making the files available.
I recently got an am6b+ and I'm very satisfied with the device, hope to get another soon. This prompt me to sell my Zidoos Z9X Pro and question whether to keep my Oppo clones. Wasn't aware but realize now that the Ugoos can't do DT P7 Fel, unlike the Oppo clones. I'm wondering, how prevalent are these DT rips? I don't rip my own Blu-Rays, I get what I find on usenet, are you guys aware if this type of files are often used in releases?
DylanValenti
texwatson wrote:
Wed Apr 10, 2024 9:21 pm
I don't think they're prevalent outisde of a full disc rip, but even if you do find one, you can easily convert it to ST P7 FEL yourself, as mentioned in this thread.
DylanValenti
@reset how did you generate rpu for films with variable l5 like oppenhiemer? I have a custom file with variable l5, but I thought the cm analyze dolby algo could not do this and it needed to be done with resolve?
DylanValenti wrote:
Thu Apr 11, 2024 10:37 am
Did it in Resolve.
DylanValenti
RESET_9999 wrote:
Thu Apr 11, 2024 10:50 am
Did it in Resolve.
I see. I thought your RPUs with the tag "Generated" used cm analyze though?
