If your firmware is younger than Dec. 2022 you are out of luck and should return it.sense wrote: Mon Mar 25, 2024 9:26 pm Hello Coopervid,
could you please send me the instructions to downgrade the XS07U to a libredrive firmware ?
BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
Read your PM.Edward1017 wrote: Mon Apr 01, 2024 7:17 am Hello Coopervid,
I also picked up one of these drives recently. Mine is on firmware 1.00.
Can you also PM me with the instructions?
brandonuhd
Looking to flash my BDR-XD07S for UHD. Coopervid, can you PM me?
TIA!
TIA!
Chillkill
Hi Coopervid,
Was about to pick up one of these drives. If it has firmware version 1.03 would I be able to roll the firmware back to a version that works with mkv? If so can you send me instructions on how to flash it? Thank you!
No, firmwares younger than Dec. 2022 can't be flashed. If so, return the drive.Chillkill wrote: Mon Apr 08, 2024 4:17 pm Hi Coopervid,
What firmware and date has the drive?brandonuhd wrote: Sat Apr 06, 2024 3:46 am Hi,
TIA!
brandonuhd
Drive InformationCoopervid wrote: Tue Apr 09, 2024 9:27 amWhat firmware and date has the drive?brandonuhd wrote: Sat Apr 06, 2024 3:46 am Hi,
TIA!
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.05
Serial number: ------
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 72
Drive platform: Pioneer RS8D30
Firmware version: GENE
You are out of luck. Firmware is newer than Dec. 2022.brandonuhd wrote: Tue Apr 09, 2024 2:32 pmDrive InformationCoopervid wrote: Tue Apr 09, 2024 9:27 amWhat firmware and date has the drive?brandonuhd wrote: Sat Apr 06, 2024 3:46 am Hi,
TIA!
Revision: 1.05
benh1
Hi Coopervid
I have the top-loading version of this drive. Will the UHD firmware work with it? If so, any chance I could have a copy?
Many thanks
Revision: 1.02
Serial number:
Firmware date: 2019-09-05
Drive platform: RS8D30
Firmware version: 1.02
Many thanks
Revision: 1.02
Serial number:
Read your PM.benh1 wrote: Thu Apr 11, 2024 12:44 pm Hi Coopervid
Many thanks
Revision: 1.02
Serial number:
NotTheOne
Hi Coopervid, could you PM the info on this too?
Post your Makemkv info.
benh1
Thank you. I have yet to flash the drive, as I've been ripping my HD discs so far. After flashing, will the drive still be a libredrive? If it won't, is there a way to go back to the factory firmware?Read your PM.
It will. And yes, that is also possible.benh1 wrote: Thu Apr 25, 2024 12:14 pmThank you. I have yet to flash the drive, as I've been ripping my HD discs so far. After flashing, will the drive still be a libredrive? If it won't, is there a way to go back to the factory firmware?Read your PM.
stoggi
Hi Coopervid,
I also got a Pioneer BDR-XS07 with Firmware 1.01.
Can you please send me a PM with the Informations to upgrade?
Thank you so much
Thank you so much
