VERY EFFECTIVE fix for Scratched Blu-Rays...
artphotodude
Post by artphotodude » Fri Apr 05, 2024 5:23 am
So have finally got around to giving this a try (will be buying FOR SURE, as soon as my next check comes in) and like a lot of people here have run across the occasional Blu-Ray that won't read properly. With DVDs, this often isn't a big deal (unless the shiny undercoating is failing), but obviously, buffing Blu-Rays doesn't work very well, and I've not had wax work at all.
BUT I accidently run across a serious fix (has worked on two discs now). I am a watch-repair hobbiest and have a little tube of a compound called Polywatch (can find easily on places like Amazon or Ebay) for removing scratches from plastic watch crystals. Just a tiny dab - rub into the scratch, wipe off excess and repeat if needed. For $7, this might be the ultimate fix to save that rare or expensive Movie!!!
kimjay10112358
Re: VERY EFFECTIVE fix for Scratched Blu-Rays...
Post by kimjay10112358 » Mon Apr 08, 2024 3:53 am
[Translator]
Smooth grinding of the surface using abrasive can be a great help in reading the information on the disk correctly.
However, another problem may arise if you intensively polish only certain areas with scratches.
Problems like the center of gravity moving away from the center of the disk, or the gentle curvature of the surface causing the refraction of the laser.
If it's a very shallow scratch, you don't have to worry too much about the above problem.
Still, the best thing to do is to polish the entire disk, not a part of it, and use a polishing machine, not a hand.
artphotodude
Post by artphotodude » Sun May 05, 2024 6:14 pm
kimjay10112358 wrote: Mon Apr 08, 2024 3:53 am [Translator]
The main issue with BRDs is the data is just beneath that hard-coating on the bottom, so you have DRASTICALLY less material to buff away before you are destroying the data itself. Polywatch as mentioned above actually fills-in the cracks with lightly-desolved material around it, so rather than buffing to below the scratch, it actually fills it in with the actual material.
DJPitaB
Post by DJPitaB » Sun Jul 21, 2024 9:19 pm
Polywatch sounds like a great solution! QQ: What are you using to wipe off the excess?
jtsapps217
Post by jtsapps217 » Thu Jul 25, 2024 3:06 pm
This is a great suggestion. I've use glass and optical cleaner before, which is obviously a different category of a thing (as it only attempts to remove dirt/grime). I would be a bit timid in buffing a disc, but if you've had success, I'd be willing to try it.
Could you detail a bit more of your process, especially (as the previous poster asked) what you use to apply and wipe off? And, how aggressive you are in the polishing? Thanks.
ZackyDog
Post by ZackyDog » Sat Aug 09, 2025 4:48 pm
Ordered.
Thanks for the tip. I can't wait to try it(!)
drxenos
Post by drxenos » Sat Aug 09, 2025 4:51 pm
Unlike DVDs and CDs, Blu-rays have an anti-scratch coating (plus, the data is MUCH closer to the surface). Trying to buff or resurface a Blu-ray will ruin it.
Blyth
Post by Blyth » Sat Aug 09, 2025 6:07 pm
For CDs and DVD brasso was always good to use, but that's if they weren't playing well in a cd player or dvd player, not sure how well it will work for software like makemkv.
I have used eye spectacle cleaner works very well when makemkv couldn't read a disc.
sivartk
Post by sivartk » Sat Aug 09, 2025 10:25 pm
Thanks for the tip, I might give it a try. I want to try it on my Point Break Blu-ray. Somehow I got it to rip (car fine cut cleaner) after about 8 tries, but put it in the player (Panasonic UB420) today and it skips again.
The again, I have The Curious Case of Benjamin Button on Blu-ray that looks like a chicken danced on it and it plays / rips just fine. So who knows? :?
