Donpoku
#9841 Post by Donpoku » Sun Apr 07, 2024 1:03 am
RESET_9999 wrote: Fri Apr 05, 2024 2:28 pm Sure I can have a look this weekend when I also compare CMV4.0 (and CE-21) but honestly, right now I'm 100% satisfied with the current build ( 20.5) I did all my tests and I'm more in my ''enjoying movies'' phase :)
Hey buddy can you please help me convert STDL.mkv(p7,p5) to STDL.mp4, Thanks
Donpoku
#9842 Post by Donpoku » Sun Apr 07, 2024 1:05 am
cpm00 wrote: Sat Apr 06, 2024 7:43 am Yes those are commands to issue on a ssh connection to the box, just short hand to change the values in those sys parameter files.
Was just trying some other things out and turns out the 2nd command will not revert fully - will need to reboot to revert fully.
Would not know where to look on the PCM conversion, could ask the CE guys on their forum, I personally use passthrough.
Thank you much appreciated buddy.
#9843 Post by RESET_9999 » Sun Apr 07, 2024 2:23 am
Donpoku wrote: Sun Apr 07, 2024 1:03 am Hey buddy can you please help me convert STDL.mkv(p7,p5) to STDL.mp4, Thanks
workflow 5 with the mp4 version of my dovi_script
Donpoku
#9844 Post by Donpoku » Sun Apr 07, 2024 6:56 am
RESET_9999 wrote: Sun Apr 07, 2024 2:23 am
How do I change mp4muxer to old - for lg c6
#9845 Post by RESET_9999 » Sun Apr 07, 2024 11:45 am
line 59
:: choose the mp4muxer version (OLD or NEW default = NEW) OLD works on (2018) LG TVS but Itunes P8 hybrid wont work if you dont fix the bitstream framerate first. And when input has lossless audio or subs, the old mp4box needed will not properly set the BL compatibility ID which doesnt seem to cause issues though.
set mp4_version=NEW
Donpoku
#9846 Post by Donpoku » Sun Apr 07, 2024 8:18 pm
RESET_9999 wrote: Sun Apr 07, 2024 11:45 am line 59
set mp4_version=NEW
Thanks RESET_9999, tried that but this old lg c6 is not having it, can you do DV fel mp4 dl (with good image/video highlights that might work on c6 internal ) and drop me a link, trying to compare to minix u22 xj max CE as I think it still using player-led? Of course when you are free, many thanks.
#9847 Post by RESET_9999 » Sun Apr 07, 2024 8:54 pm
Just make yourself one with workflow 4-3
DylanValenti
#9848 Post by DylanValenti » Mon Apr 08, 2024 10:48 am
What’s the workflow to inject fixed P7 FEL RPU back into video without converting it to P8 (doing this for avatar the way of water)
#9849 Post by RESET_9999 » Mon Apr 08, 2024 11:20 am
workflow (1-1) but you have to add ''JUSTINJECT'' in the BL filename to keep it P7
DylanValenti
#9850 Post by DylanValenti » Mon Apr 08, 2024 11:58 am
RESET_9999 wrote: Mon Apr 08, 2024 11:20 am workflow (1-1) but you have to add ''JUSTINJECT'' in the BL filename to keep it P7
I see thank you!
Yoshitaka
#9851 Post by Yoshitaka » Mon Apr 08, 2024 5:05 pm
Which DV profiles in MP4 container work on QM850G?
Does MKV work?
Donpoku
#9852 Post by Donpoku » Tue Apr 09, 2024 8:28 am
RESET_9999 wrote: Sun Apr 07, 2024 8:54 pm Just make yourself one with workflow 4-3
Hi RESET, your fel test looks different on my lg c6, what is your DV picture mode settings i.e oled light, contrast etc? Thanks, your can pm if don't want it public. Mine is oled light: 100; contrast: 95; brightness:50 ;sharpness: 10; colour: 85 and tint:0.
#9853 Post by RESET_9999 » Tue Apr 09, 2024 10:57 am
Different? Dont compare the picture from a youtube video with what you see in real life. The point of the FEL test file is that you can see the text that tells you your devices support FEL and the brightness change to L1 L2 L8
My C2 is calibrated in Cinema mode OLED 100.
DylanValenti
#9854 Post by DylanValenti » Tue Apr 09, 2024 1:01 pm
For cm analyze I noticed that I got a message
“WARNING plugin does not contain dlb_plugin_file_io_init_v1”
However it seems to be proceeding despite that warning. Should I be worried or am I fine?
#9855 Post by RESET_9999 » Tue Apr 09, 2024 1:29 pm
it says that with the latest CM version. It doesn't affect the outcome.
