The Abyss 4K
Radiocomms237
Re: The Abyss 4K
Post by Radiocomms237 »
saf001 wrote: Fri Apr 05, 2024 12:15 am ~ the first file, theatrical version, completed but had several AV sync issues in stream errors. Because of this I did not try to play it yet. Second file, extended or special, failed. In this case a lot of Scsi error - MEDIUM ERROR L-EC UNCORRECTAABLE or STATUS_DEVICE_DATA_ERROR. No idea. ~
AV Sync issues are usually nothing to be concerned about (unless they're HUGE).
When there are multiple editions of a title on the same disc utilizing seamless branching (where most segments are duplicated between the two playlists but some are unique), it's typical to see MakeMKV correcting small sync issues by dropping or adding frames, usually on the transitions from one segment to the next.
The UNCORRECTABLE MEDIUM ERRORS, on the other hand, indicate that the drive can't read 100% of the data from the disc. If the disc isn't damaged, you could try cleaning/polishing, but judging by other comments in this thread, I wouldn't be too optimistic.
Surely, if there are enough people returning these discs, they will have to do something about the problem eventually?
saf001
Re: The Abyss 4K
Post by saf001 »
Thanks for the information regarding AV Sync. It didn't seem to be too bad and mostly in stream 5(?) but also had the Scsi errors mixed in. I'm not sure when one save vs the other failed but maybe I'll go ahead and watch it tonight. It wasn't as as my copy of The Witness. That spewed them non stop sadly.
Looking at the log file for the extended cut of the Abyss it appears it started to fail at the 2:14:14 marker.
I'm using the Asus BW-16D1HT and don't know the firmware version. Log file indicates SDF v098: ASUS_BW-16D1HT_3.02 so maybe 3.02?
Roadwarrior980
Re: The Abyss 4K
Post by Roadwarrior980 »
I'm not sure what happened tonight, but i decided to give this another try on my Asus BW-16D1HT, and i was successful with the theatrical version with no faults. In the process of giving the special edition another go now.
Nothing was done different from previous attempts, and my discount had the scratch towards the outer edge that others seem to have issues with.
croweyes1121
Re: The Abyss 4K
Post by croweyes1121 »
I've now had THREE copies of this disc with circular scratches that would not rip (the same files either skip or freeze on my standalone player). There have to be some serious and widespread QC issues with this one...
midnighwatcher
Re: The Abyss 4K
Post by midnighwatcher »
My third disc finally ripped on the first try. :o
CalicoSkies
Re: The Abyss 4K
Post by CalicoSkies »
Has anyone tried contacting the publisher of this release to ask about this and whether they'll replace the 4K disc? Some manufacturers have done that, and I've had DVDs replaced in the past that way. It sounds like this release is published by Walt Disney Home Studios Entertainment? I wonder if that could be a route to get a good disc, rather than returning and buying another copy.
This page has contact information for Walt Disney, including a link to a form to send them an email:
https://support.disney.com/hc/en-us/art ... ey-Studios
smurray5
Re: The Abyss 4K
Post by smurray5 »
I'm exchanging mine through Amazon. If the replacement has the same problem then I'll try contacting the publisher.
smurray5
Re: The Abyss 4K
Post by smurray5 »
I ordered a replacement of my UHD disc from Amazon and both Theatrical and SE ripped just fine.
CalicoSkies
Re: The Abyss 4K
smurray5 wrote: Thu Apr 11, 2024 3:20 am I ordered a replacement of my UHD disc from Amazon and both Theatrical and SE ripped just fine.
What's the process to replace just the UHD disc with Amazon? I thought you could only return or replace the whole package.
CalicoSkies
Re: The Abyss 4K
I got an alert that Target has The Abyss 4K back in stock (at $24.99 + shipping). I bought another copy from them, and I'll try to rip again when it arrives. This will be my 3rd attempt.
Damundai
Re: The Abyss 4K
Post by Damundai »
At least some of you are still having some luck ripping the disc. My drive:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.03
Still won't even decrypt it. I have downloaded sdf.bin and keydb.cfg (4/12/24) and still nothing. Disc is clean. Internet access enabled. Don't know what the heck to do next.
Return the disc for another copy?
I know the drive works as I am currently ripping multiple other 4K discs with it and it is working with them just fine.
Re: The Abyss 4K
dont think 1.03 on that drive will ever work whats the fw date?
Damundai
Re: The Abyss 4K
Post by Damundai »
Billycar11 wrote: Sat Apr 13, 2024 6:15 am dont think 1.03 on that drive will ever work whats the fw date?
Revision: 1.03
Serial number: xxxxxxxxxxx
Firmware date: 2020-08-20
Like I said, it's working with other 4K discs, just not this one.
Even tried this known good drive to no avail:
Product: BD-RW BDR-XD08U
Revision: 1.00
Firmware date: 2022-04-03
Disc is clean and clear with not a scratch or swirl mark on it.
Dump File: MKB20_v77_THE_ABYSS_C144.tgz
mainecooncat1
Re: The Abyss 4K
Post by mainecooncat1 »
I returned my scratched copy to Amazon about a week ago and just received a new copy from Wal-Mart. The internal packaging is different (4K disc isn't stacked on top of the bonus features disc). MakeMKV also reports that the "volume key is unknown for this disc - video can't be decrypted." It appears as MKB20_v77_THE_ABYSS_1436.tgz. I've submitted the new dump file by email to svq@makemkv.com.
Re: The Abyss 4K
Damundai wrote: Sat Apr 13, 2024 2:28 pm
Revision: 1.03
Revision: 1.00
Ahh got it confused with xs07 1.03
1.03 on xd07 is fine
