Star Wars The Force Awakens 4K
LordVader2K
Post by LordVader2K » Wed Apr 03, 2024 5:32 pm
Hello
New to the forums and makemkv as well.
I'm trying to rip Star Wars The Force Awakens 4K.
I've read not all but a majority of the post concerning this issue with either the Skywalker saga or stand alone disk.
Since it hasn't been an update since 2020, is there a way now to fix this error.
I tried copy the entire disk on the internal hard drive but when it comes to create the mkv file at the end error and no save.
Copied a .ISO file and mount it same result.
I'm wondering if this is still an issue or is it my equipement that is not able to work as intended.
The drive is brand new and with other disk I have no problem at all.
Thanks for the follow up.
Re: Star Wars The Force Awakens 4K
Post by dcoke22 » Wed Apr 03, 2024 8:41 pm
Can you copy & paste the log MakeMKV has when you try to rip this disc?
LordVader2K
Post by LordVader2K » Thu Apr 04, 2024 8:31 am
Here is the log when trying to rip directly form the UHD disk.
MakeMKV v1.17.6 win(x64-release) started
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Title #00302.mpls has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00105.mpls has length of 21 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00104.mpls has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00102.mpls has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00101.mpls has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00004.mpls was added as title #0
File 00802.mpls was added as title #1
Title #00002.mpls has length of 3 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00042.mpls has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00041.mpls has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00040.mpls has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00301.mpls has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00106.mpls has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00900.mpls has length of 20 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00020.mpls was added as title #2
Title #00300.mpls has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00803.mpls was added as title #3
File 00801.mpls was added as title #4
Title #00100.mpls has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00800.mpls was added as title #5
Title #00902.mpls has length of 30 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00901.mpls has length of 30 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00016.mpls has length of 3 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00306.mpls has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00305.mpls has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00015.mpls has length of 3 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00035.m2ts has length of 41 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00032.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00031.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00030.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00029.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00028.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00026.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00023.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00022.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00021.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00020.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00017.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00002.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00078.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00075.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00150.m2ts has length of 1 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00069.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00072.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00071.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00070.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00018.m2ts has length of 30 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00151.m2ts has length of 2 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00053.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00052.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00050.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00049.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00048.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00025.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00024.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00045.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00044.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00043.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00042.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00006.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00001.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00015.m2ts has length of 2 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00009.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00033.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00011.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00010.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00039.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00038.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00037.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00036.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00054.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00051.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00079.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00077.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00047.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00076.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00074.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00073.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00008.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00019.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00068.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00067.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00066.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00065.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00064.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00046.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title 00004.mpls is equal to title 00800.mpls and was skipped
Saving 1 titles into directory E:/
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00056.m2ts' at offset '29782308864'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '29782308864'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '29782308864'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00056.m2ts' at offset '29782308864'
Failed to save title 4 to file E://Star Wars- The Force Awakens_t04.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Post by dcoke22 » Thu Apr 04, 2024 1:09 pm
Here's the first error I see:
It looks like every other error in the log is a variation of the same thing; the optical drive hit a spot on the disc it was unable to read (at offset 29782308864).
The standard advice is to gently clean the disc and try again.
LordVader2K
Post by LordVader2K » Thu Apr 04, 2024 3:43 pm
I did clean it before posting, after your advice I cleaned it with distilled water.
It works, it ripped without any error.
Thank you.
TheRealAlexDC
Post by TheRealAlexDC » Sun Sep 07, 2025 12:42 pm
Hello, I'm new to the MakeMKV and Bluray ripping world. I started trying to rip the 4k versions from The Skywalker Saga, for The Force Awakens 4k, I get this error below but not sure what it all means, can someone help? I cleaned the disc and the drive is new.
MakeMKV v1.18.1 darwin(arm64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.03 MOAP41G1552d" opened in OS access mode.
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Title #00302.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00301.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00900.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00300.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00803.mpls was added as title #2
File 00801.mpls was added as title #3
Title #00100.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #4
Title #00902.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00901.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00306.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00305.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00150.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00069.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00151.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00045.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00044.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00047.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00068.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00067.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00066.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00065.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00064.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00046.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/T7 SSD/MakeMKV/Star Wars- The Force Awakens
The source file '/BDMV/STREAM/00056.m2ts' is corrupt or invalid at offset 26393806848, attempting to work around
Hash check failed for file 00056.m2ts at offset 26393831424, file is corrupt.
The source file '/BDMV/STREAM/00056.m2ts' is corrupt or invalid at offset 26393806848-26393812992, attempting to work around
The source file '/BDMV/STREAM/00056.m2ts' is corrupt or invalid at offset 26393812992, attempting to work around
The source file '/BDMV/STREAM/00056.m2ts' is corrupt or invalid at offset 26393812992-26393819136, attempting to work around
The source file '/BDMV/STREAM/00056.m2ts' is corrupt or invalid at offset 26393819136, attempting to work around
The source file '/BDMV/STREAM/00056.m2ts' is corrupt or invalid at offset 26393819136-26393825280, attempting to work around
The source file '/BDMV/STREAM/00056.m2ts' is corrupt or invalid at offset 26393825280, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00056.m2ts' (title #-) , future messages will be printed only to log file
Hash check failed for file 00056.m2ts at offset 26394028032, file is corrupt.
Hash check failed for file 00056.m2ts at offset 26394224640, file is corrupt.
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00056.m2ts' at offset '26394335232'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '26394335232'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00056.m2ts' at offset '26394335232'
Failed to save title 3 to file /Volumes/T7 SSD/MakeMKV/Star Wars- The Force Awakens/Star Wars- The Force Awakens_t03.mkv
Encountered 6 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Encountered 3 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
Post by dcoke22 » Thu Sep 11, 2025 4:31 pm
TheRealAlexDC wrote: Sun Sep 07, 2025 12:42 pm Hello, I'm new to the MakeMKV and Bluray ripping world. I started trying to rip the 4k versions from The Skywalker Saga, for The Force Awakens 4k, I get this error below but not sure what it all means, can someone help? I cleaned the disc and the drive is new.
Messages like this:
mean the optical drive is unable to correctly read a spot on the disc. The standard advice is to gently clean the disc and try again.
