Blu ray rip crimes of grindelwald missing language
Chiller8891
Post by Chiller8891 »
Hello together, I tried to rip the grindelwald blu ray with German and English language. But when I open the disk I just see the English audio. It's the German disk therefore it should be there.
Ran into the same problem some times now.
Fishermen
Re: Blu ray rip crimes of grindelwald missing language
Post by Fishermen »
Same issue here - have you found a solution? I think on the BR there are acually two versions of the movie: Extended and Cinema Version. Extended is only available in English, Cinema should be available also in German. But when i run MakeMKV, i only see the video file of the extended version (141 min.) - hence also only english audio track. Any possibility to rip the cinema version instead?
Chiller8891 wrote:
Mon Jan 15, 2024 1:45 pm
On the Language tab in MakeMKV Preferences, do you have a preferred language set? What happens it you set it to 'none'?
Fishermen wrote:
Thu Apr 04, 2024 7:10 am
According to DVDCompare: https://www.dvdcompare.net/comparisons/film.php?fid=49886#6
The theatrical version and the extended version are on different discs on the German releases.
Fishermen
Post by Fishermen »
That was a really dump first post from me........ please apologize.
The second disc was covered by a inlay on the other side of the cover and i even tried to rip the disc several times with different machines.
If i had read the printing of the disc i would have also seen that its two different discs in the box..
