ASUS SBW-06D2X-U
Merc1985
ASUS SBW-06D2X-U
Post by Merc1985 » Wed Apr 03, 2024 5:09 pm
I've had this drive for some time and just decided to try MKV. Is it possible to read/rip with this drive or do I need to purchase another?
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: THDL186772WL
Firmware date: 2017-04-18
Highest AACS version: 68
Firmware version: ID22
Re: ASUS SBW-06D2X-U
Post by dcoke22 » Wed Apr 03, 2024 8:57 pm
https://forum.makemkv.com/forum/viewtopic.php?p=129189#p129189
Has MakeMKV produced a firmware dump for your drive?
According to the LibreDrive for Pioneer drives thread, your RS8511 platform should be supported.
Whatever you do, don't blindly update the firmware on the drive as that could make it incompatible with MakeMKV. Pioneer firmware update February 2023
Merc1985
Post by Merc1985 » Wed Apr 03, 2024 9:01 pm
MakeMKV did produce a dump file and I sent it to support. Thanks for the info on the Feb 2023 firmware update, i wasn't aware of that and will not do it.
Post by Coopervid » Wed Apr 03, 2024 9:28 pm
Manufacturer: ASUS
Revision: 1.10
Just wait. I will check.
Post by Coopervid » Wed Apr 03, 2024 9:42 pm
This drive can be upgraded to UD04 and can read UHDs and will be Libredrive compatible.Read your PM.
Merc1985
Post by Merc1985 » Thu Apr 04, 2024 10:49 am
Worked great. Thanks for the help!
Freeman4
Post by Freeman4 » Mon Apr 22, 2024 7:42 pm
Hello, i have the same Asus drive with the same Drive platform and firmware version according to MakeMKV.
What's the procedure to update the firmware to be LibreDrive friendly?
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: ALDL237138WL
Freeman4
Post by Freeman4 » Wed Apr 24, 2024 7:54 am
Thanks to Billycar11 for his help, my drive is now LibreDrive enabled.
Post by Coopervid » Wed Apr 24, 2024 9:19 am
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Read your PM.
Wartutor
Post by Wartutor » Fri Apr 26, 2024 6:06 am
Any way i can get the directions also, please.
Post by Coopervid » Fri Apr 26, 2024 1:34 pm
Post your Makemkv info.
Wartutor
Post by Wartutor » Sat Apr 27, 2024 9:05 am
Drive information
Manufacturor: Asus
Serial number: MO6N9391347
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Highest AACS version: 75
LibreDrive Infomation
rye-amts
Post by rye-amts » Wed May 01, 2024 9:12 pm
Recently I discovered that BD drives could become friendly with UHD discs. I, also, have an ASUS SBW-06D2X-U and I would appreciate any guidance as to how I can update it. However, I do not know if there are limitations as a Mac user(?)
Manufacturer: ASUS
Revision: 1.03
Serial number: QADL015495WL
Firmware date: 2016-12-16
Highest AACS version: 81
Drive platform: RS8510
Firmware version: 1.03/ID22
Post by Billycar11 » Wed May 01, 2024 9:55 pm
Manufacturer: ASUS
Revision: 1.03
on mac your out of luck
if you have access to a pc email me that drive info and i can sell you an automated flasher for $25
rye-amts
Post by rye-amts » Wed May 01, 2024 10:26 pm
I suspected this could be the case. How unfortunate. I could probably get access to my wife's PC at her work. Is it a simple procedure?
