Star Wars The Force Awakens 4K
LordVader2K
Post by LordVader2K »
Hello
New to the forums and makemkv as well.
I'm trying to rip Star Wars The Force Awakens 4K.
I've read not all but a majority of the post concerning this issue with either the Skywalker saga or stand alone disk.
Since it hasn't been an update since 2020, is there a way now to fix this error.
I tried copy the entire disk on the internal hard drive but when it comes to create the mkv file at the end error and no save.
Copied a .ISO file and mount it same result.
I'm wondering if this is still an issue or is it my equipement that is not able to work as intended.
The drive is brand new and with other disk I have no problem at all.
Thanks for the follow up.
Re: Star Wars The Force Awakens 4K
Can you copy & paste the log MakeMKV has when you try to rip this disc?
LordVader2K
Here is the log when trying to rip directly form the UHD disk.
MakeMKV v1.17.6 win(x64-release) started
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Title #00302.mpls has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00105.mpls has length of 21 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00104.mpls has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00102.mpls has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00101.mpls has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00004.mpls was added as title #0
File 00802.mpls was added as title #1
Title #00002.mpls has length of 3 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00042.mpls has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00041.mpls has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00040.mpls has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00301.mpls has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00106.mpls has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00900.mpls has length of 20 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00020.mpls was added as title #2
Title #00300.mpls has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00803.mpls was added as title #3
File 00801.mpls was added as title #4
Title #00100.mpls has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
File 00800.mpls was added as title #5
Title #00902.mpls has length of 30 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00901.mpls has length of 30 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00016.mpls has length of 3 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00306.mpls has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00305.mpls has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00015.mpls has length of 3 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00035.m2ts has length of 41 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00032.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00031.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00030.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00029.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00028.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00026.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00023.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00022.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00021.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00020.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00017.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00002.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00078.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00075.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00150.m2ts has length of 1 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00069.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00072.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00071.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00070.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00018.m2ts has length of 30 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00151.m2ts has length of 2 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00053.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00052.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00050.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00049.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00048.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00025.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00024.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00045.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00044.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00043.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00042.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00006.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00001.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00015.m2ts has length of 2 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00009.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00033.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00011.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00010.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00039.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00038.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00037.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00036.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00054.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00051.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00079.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00077.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00047.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00076.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00074.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00073.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00008.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00019.m2ts has length of 8 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00068.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00067.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00066.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00065.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00064.m2ts has length of 5 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #00046.m2ts has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title 00004.mpls is equal to title 00800.mpls and was skipped
Saving 1 titles into directory E:/
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00056.m2ts' at offset '29782308864'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '29782308864'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '29782308864'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00056.m2ts' at offset '29782308864'
Failed to save title 4 to file E://Star Wars- The Force Awakens_t04.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Here's the first error I see:
It looks like every other error in the log is a variation of the same thing; the optical drive hit a spot on the disc it was unable to read (at offset 29782308864).
The standard advice is to gently clean the disc and try again.
LordVader2K
I did clean it before posting, after your advice I cleaned it with distilled water.
It works, it ripped without any error.
Thank you.
