ASUS SBW-06D2X-U
Merc1985
ASUS SBW-06D2X-U
I've had this drive for some time and just decided to try MKV. Is it possible to read/rip with this drive or do I need to purchase another?
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: THDL186772WL
Firmware date: 2017-04-18
Highest AACS version: 68
Firmware version: ID22
Manufacturer: ASUS
Revision: 1.10
Re: ASUS SBW-06D2X-U
https://forum.makemkv.com/forum/viewtopic.php?p=129189#p129189
Has MakeMKV produced a firmware dump for your drive?
According to the LibreDrive for Pioneer drives thread, your RS8511 platform should be supported.
Whatever you do, don't blindly update the firmware on the drive as that could make it incompatible with MakeMKV. Pioneer firmware update February 2023
Merc1985
MakeMKV did produce a dump file and I sent it to support. Thanks for the info on the Feb 2023 firmware update, i wasn't aware of that and will not do it.
Just wait. I will check.Merc1985 wrote: Wed Apr 03, 2024 5:09 pm Hi,
Manufacturer: ASUS
Revision: 1.10
This drive can be upgraded to UD04 and can read UHDs and will be Libredrive compatible.Read your PM.
Merc1985
Worked great. Thanks for the help!
Freeman4
Hello, i have the same Asus drive with the same Drive platform and firmware version according to MakeMKV.
What's the procedure to update the firmware to be LibreDrive friendly?
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: ALDL237138WL
No disc inserted-
Freeman4
Thanks to Billycar11 for his help, my drive is now LibreDrive enabled.
Read your PM.Freeman4 wrote: Mon Apr 22, 2024 7:42 pm Hello, i have the same Asus drive with the same Drive platform and firmware version according to MakeMKV.
Drive Information OS device name: F: Manufacturer: ASUS Product: SBW-06D2X-U Revision: 1.10 Serial number: ALDL237138WL Firmware date: 2017-04-18 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8511 Firmware version: ID22 No disc inserted
Wartutor
Any way i can get the directions also, please.
Post your Makemkv info.
Wartutor
Drive information
Manufacturor: Asus
Serial number: MO6N9391347
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Highest AACS version: 75
LibreDrive Infomation
Manufacturor: Asus
rye-amts
Recently I discovered that BD drives could become friendly with UHD discs. I, also, have an ASUS SBW-06D2X-U and I would appreciate any guidance as to how I can update it. However, I do not know if there are limitations as a Mac user(?)
Manufacturer: ASUS
Revision: 1.03
Serial number: QADL015495WL
Firmware date: 2016-12-16
Highest AACS version: 81
Drive platform: RS8510
Firmware version: 1.03/ID22
Unrestricted read speed: Yes-
on mac your out of luckrye-amts wrote: Wed May 01, 2024 9:12 pm Recently I discovered that BD drives could become friendly with UHD discs. I, also, have an ASUS SBW-06D2X-U and I would appreciate any guidance as to how I can update it. However, I do not know if there are limitations as a Mac user(?)
Drive Information Manufacturer: ASUS Product: SBW-06D2X-U Revision: 1.03 Serial number: QADL015495WL Firmware date: 2016-12-16 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8510 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.03/ID22 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
if you have access to a pc email me that drive info and i can sell you an automated flasher for $25
rye-amts
I suspected this could be the case. How unfortunate. I could probably get access to my wife's PC at her work. Is it a simple procedure?Billycar11 wrote: Wed May 01, 2024 9:55 pm on mac your out of luck
